goychman
VCU118 SDK issue
I'm trying to run a small software on a micro-blaze CPU that I have in my design but after programming the FPGA and trying to run the software from the SDK, I'm getting the following error:
ERROR : Unexpected error while launching program.
com.xilinx.sdk.targetmanager.TMException: Connection to Board Failed
Could not find a supported debug device on the board.Check if the jumper settings on the board are correct
at com.xilinx.sdk.targetmanager.internal.TM.isFPGAConfigured(TM.java:374)
at com.xilinx.sdk.debug.core.XilinxAppLaunchConfigurationDelegate.isFpgaConfigured(XilinxAppLaunchConfigurationDelegate.java:409)
at com.xilinx.sdk.debug.core.XilinxAppLaunchConfigurationDelegate.launch(XilinxAppLaunchConfigurationDelegate.java:303)
at com.xilinx.sdk.debug.ui.XilinxAppLaunchDelegateWrapper.launch(XilinxAppLaunchDelegateWrapper.java:31)
It's the first time I'm seeing this error, I work before with different FPGA evaluation boards (zynq, artix, kintex, virtex, kintex ultra-scale and zynq ultra-scale+), but I never saw this error before.
yodasoda
This looks like the issue:
"Could not find a supported debug device on the board.Check if the jumper settings on the board are correct"
stephenm
Seems like the MDM isnt detected? Are you programming the FPGA?
Can you do a check in XSCT to see if the MDM is detected
fpga -f download.bit
connect
targets
This will list the targets
nikhilageorge89
I also face the same issue. For me the MDM is listed.
ibaie
Hi @goychman,
Did you make any progress on this issue? Would be great to see if you finally fix the issue
Ibai
yodasoda
