VHDL code to access AXI interfaces
the vivado will generate VHDL templates for AXI interfaces. I am looking for examples how to write the VHDL code to access the three different AXI interfaces. There is a comprehensive documentation on complex AXI interfaces, but where can I learn to build just a very simple interface.
Bahne
Are you trying to create your user IP with an AXI Interface?  If yes you can use "Create and Packaging IP Wizard"  page45 of
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_3/ug896-vivado-ip.pdf
--Hem
Hello Hem,
Thank you for your Answer. I was looking for the code, how to transfer data to and from AXI interfaces.
The
               AR#56609 (http://www.xilinx.com/support/answers/56609.htm)
offered a template, but I was confused because the it requires so much code to establish a simple interface.
It would exactly meet my requirements, if I could have the files from
               xapp1168 (http://www.xilinx.com/support/documentation/application_notes/xapp1168-axi-ip-integrator.pdf)
in VHDL instead in verilog.
Bahne
moving to embedded board
Deepika.
Bahne, did you determine a solution? Did you just translate the verilog code? I'm in a similar situation, and I'm trying to look for an existing solution before creating my own...
I was reading through UG896 that htsvn linked to. This is what I was trying to figure out, thanks! The wizard generates the VHDL code that acts as a template for implementing your custom function.
So, any chance Xilinx starts to support the AXI interfaces in VHDL?
i'm in the same situation. Seaching for an AXI oder at least AXI-Lite VHDL Interface. For building my own VHDL Code  communication with MicroBlaze ( -> Ethernet).
Maybe Xilinx will put this on their record, for future dev..
Hopefully they will notice that their is interest, out there :-)
regards Apfelsaft
You can check the source code for some of the AXI peripherals that Xilinx provides in Vivado.
Not every IP is encrypted and it can give you a idea on how AXI interface is used.
Göran
