NOSAM_08
VITIS (v2020.2) - BSP/FreeRTOS files don't show up as "External SDK Calls" when using syntax coloring
I'm trying to use the 'Syntax Coloring' feature of the VITIS/Eclipse IDE to highlight functions from the BSP as 'External SDK Calls'. I.E., the functions inside the BSP would have the same color scheme as functions from the standard C library like the example below:
printf("Hello World");
vTaskStartScheduler();
Instead, the syntax color scheme of the BSP is the same as just the regular 'function' settings. Here is a sample of my code for reference:
Does anybody know how to make VITIS/Eclipse read the BSP functions as 'External SDK Calls' like the printf(); in my example?
I'd really appreciate it!
