michielk
Vitis 2020.2 Error initializing SD boot data
I'm trying to build a very basic project in Vitis for the ZCU102 board. In this case, just using the standard zcu102 xsa file for the board and the "Hello World" application project example template. This, and other simple projects, building a bitstream in Vivado invariably fail in Vitis on the error below. The zcu102 board files are installed in Vivado and Vitis ... any suggestion what might be the problem here?
longley
I don't see this error before. But if you are using the xsa files that are installed in Vitis installation, I think there might be something wrong with your building steps.
Please follow steps in Chapter3 of UG1209 to create a platform and build a helloworld to see if it still has the same issue.
Longley
Versal Blogs
