aalvarez
Vitis 2020.2 SPI SREC BootLoader Example
The Vitis 2020.2 SPI SREC Boot Loader example application is no longer valid due to the deprecation of the Xilisf library. However, it's still included in the application templates selections within 2020.2. Is there an updated bootloader template available that will work with 2020.2?
tj-scherer
If you upgrade to 2021.1 the template no longer uses the xilisf library. I have been unable to actually get it fully working due to other issues with my design though.
aalvarez
Thank you for your response. I ended up dropping back to Vitis 2020.1. This appears to be the last version that still contains the xilisf library. I generated the bootloader using Vitis 2020.1. but for all other application code 2020.2 was used.
