Mark
Vitis 2020.2 & "Missing System Project"
Setup: dual microblaze instantiation (processor_0 & processor_1)
Directory structure:
root/common_microblaze_lib/
root/hardware_platform/
root/app/app-microblaze_system
root/app/app-microblaze_0/
root/app/app-microblaze_1/
To make this all work I have to create the project in Vitis and it puts everything in root/.   I then delete the projects from Vitis, move the projects in my shell, then import the projects back into Vitis.  Everything works until I try and do the second microblaze (microblaze_1) which reuses the same 'system' as microblaze_0.  When I import that project I get "Missing System Project".  If I create the app (microblaze_1) and have it create a new system, when I import the project, everything works ok.  I believe this is a bug in 2020.2.
marcb
Hi @Mark
Is the import using a .zip archive from the Vitis export?
Are there two separate import archives where each has a system project and one of the applications?
Mark
No, I'm just trying to import from a location on my hard drive to which I checked out my library from git.
Mark
@marcb
Here's a much simpler use case:
Create a library project inside a system.
Delete the project from the system.
Try and import it back into the system.
You always get "Missing System Project"
