joe306
Vitis 2020 Programming Boot Flash
Hello, I've been using Vitis 2019 and have been able to program the boot memory  which is QSPI and able to get the PL and PS to boot up problem. All good! Now I have updated to Vitis 2020.2 and after I program the device I only get the PL side working the the code running on ARM Core 0 does not run. All I have on the PL side is LEDs blinking and the PS ARM 0 should be blinking LEDs but they don't. I don't know why the PS side is not running I know things are a little different in Vitis2020 but I create the boot image the same as before. I am not using an OS, this is bare-metal. There must be something that I am doing that is different than what I did in 2019.
I'll try uploading my design for anyone willing to help me get the PS working.
Thank you
joe306
I wanted to say that when the Flash Programming Tool finished it finished successfully. I also I had no problem running the code in the Debug mode.
Here is the boot image file:
//arch = zynqmp; split = false; format = BIN
the_ROM_image:
[bootloader, destination_cpu = a53-0]D:/Projects/CLC_FPGA_BRD_Vitis2020/FPGA_BRD/Vitis_Workspace/FPGA_plat/export/FPGA_plat/sw/FPGA_plat/boot/fsbl.elf
[destination_device = pl]D:\Projects\CLC_FPGA_BRD_Vitis2020\FPGA_BRD\Vitis_Workspace\MyHello_World_LEDS\_ide\bitstream\Top_Block_wrapper_U.bit
[destination_cpu = a53-0]D:/Projects/CLC_FPGA_BRD_Vitis2020/FPGA_BRD/Vitis_Workspace/MyHello_World_LEDS/Debug/MyHello_World_LEDS.elf
joe306
Here is the view of the Vitis Flow:
joe306
The FPGA_plat directory is too large to upload. What can I take a screen shot that may help find?
joe306
the_ROM_image:
