guy.berger
Vitis - Custom plugin
I am trying to load a custom plugin for eclipse to Vitis 2019.2.
The plugin was created by Xilinx SDK 2015.4 for eclipse, and is loaded by copying the .jar file to the plugins folder of eclipse as detailed here: https://www.codeproject.com/Tips/893547/How-to-Create-Your-Own-Eclipse-IDE-Plug-in
The plugin is working fine in Xilinx SDK 2015.4 and in eclipse Photon (which is the eclipse version used in Vitis 2019.2 as far s I know),
however, when copying the plugin file to C:\Xilinx\Vitis\2019.2\eclipse\win64.o\plugins\ it doesn't appear when Vitis Loads.
Any help is welcome
stephenm
as far as I know, there is no support ofr plug-in in Vitis
stephenm
guy.berger
I've accepted as solution but this is a big drawback for us.
We've worked with a custom plugin in SDK for a long time and it is a part of our workflow.
Are plugins going to be supported in future versions of Vitis? (close future)
Or is there a way around it?
Thanks for the answer.
stephenm
By plugin, I assume you mean user extensions to the Eclipse GUI? We don’t currently intend to support that, but since Vitis is a set of command line tools users can use Eclipse CDT or some other IDE (or command line flow) should they choose to.
j1ingers
I can understand the reluctance to allow the user to modify the install and potentially break the Vitis environment but this short "not gonna do it" plan is a real hinderance.  If Xilinx' official recommendation is to use a standard Eclipse CDT, then I would expect you to point us to a Wiki that shows this tie in.  Are the compilers the same?  Are there special flags that have to be set?  Do I need to make the BSP in Vitis and then open it in the other environment?
This forum post is really lacking.
