Vitis Platform
Hello, quick question for the forum members about Vitis. I have Vivado/Vitis 19.2 installed and I understand that in Vitis you create a Platform Project and an Application Project. I understand that the Platform Project uses the xsa file from my Vivado design. Here is my question if I need to change the Vivado design and then Re-Synthesis, Run Implementation, Create the Bit file and Export the HW, do I then need to Build the Platform Project again?
Thank you
Joe
Hi @joe306
You need to update the platform project with the new XSA:
https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/ssi1556172680620.html
Hi @joe306
Thank you very much.
Hi @florentw
Is there a way to retarget the application to a new XSA / Platform Project?
As I incrementally grow the platform, I want to preserve the older Platform Project without "overwriting it" (sure I can update again with old XSA).
Thanks, looked through Application Project properties, but nothing stood out.
Jerry
I found that it's possible through Update Hardware Specification.
Sorry, getting used to this platform.
