Vitis build error
I'm new to Vitis 2020.1 and I'm attempting to create a platform project using an .xsa file exported from Vivado 2020.1. This .xsa file is created starting from an old Vivado 2018 project.
Every time I try to build the platform project in Vitis, the following errors show up:
Any suggestion on how can I solve it?
Thanks in advance.
Hi @amilani
Can you attach the <Vitis_Workspace>/<application>/Debug/<application>_Debug.build.ui.log? This will allow the community to help better.
Hi @marcb,
here it is, I hope it's the right one
Hi @amilani
Do you mean that the XSA was created with Vivado 2018 release? Mixing release between Vitis and SDK/Vitis is not a supported use case.
Anyway taking a look to the log file, it seems there is an issue building the driver code for MonitorController_v1_0 IP, which seems to be a custom IP, is that right?
arm-none-eabi-ar: *.o: Invalid argument
It seems for me that something might be wrong in the Makefile.
Ibai
Hi @ibaie,
the XSA is created in Vivado 2020.1 release, modifying an old project that was created on Vivado 2018.3.
Yes, the MonitorController_v1_0 is a custom IP.
There's a way to modify the Makefile in order to remove this error or some documentation to look for?
Regards.
