Vitis2019.2 can not open
I found my vitis 2019.2 can not open.
I click Xilinx Vitis IDE 2019.2, it then showed
did not come to
So I can not choose a workspace and go on later coding.
windows task manager shows,
the eclipse.exe occupied too much CPU and mem
I uninstalled vitis and clean the register and reinstall it, but thing did not become good.
by the way , I use win7 system, does anyone meet this kind of issue? can give me a help?
C:\Users\zhangyi\.Xilinx\Vitis\2019.2\1591580801926.log
!SESSION 2020-06-08 09:46:41.692 -----------------------------------------------
eclipse.buildId=2019.2
java.version=9.0.4
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN
Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2020-06-08 10:11:31.333
!MESSAGE Application error
!STACK 1
java.lang.IllegalArgumentException: -2147483642 > 6
at java.base/java.util.Arrays.copyOfRange(Unknown Source)
at org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.lambda$6(ChooseWorkspaceDialog.java:384)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.collect(Unknown Source)
at org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.createUniqueWorkspaceNameMap(ChooseWorkspaceDialog.java:388)
at org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.createRecentWorkspacesComposite(ChooseWorkspaceDialog.java:322)
at org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.createDialogArea(ChooseWorkspaceDialog.java:176)
at com.xilinx.ide.application.ui.ide.ChooseWorkspaceWithRestoreDialog.createDialogArea(ChooseWorkspaceWithRestoreDialog.java:44)
at org.eclipse.jface.dialogs.TitleAreaDialog.createContents(TitleAreaDialog.java:158)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1096)
at org.eclipse.jface.window.Window.open(Window.java:783)
at org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.prompt(ChooseWorkspaceDialog.java:114)
at com.xilinx.ide.application.ui.Application.promptForWorkspace(Application.java:270)
at com.xilinx.ide.application.ui.Application.checkInstanceLocation(Application.java:186)
at com.xilinx.ide.application.ui.Application.start(Application.java:72)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
can anyone help me out the problem?
is there anyone who have the same problem and can help me?
I'm having the same problem on 2020.1 on Ubuntu 18.04.5
It appears Vitis is full of bugs at this moment.
!SESSION 2020-10-06 20:36:32.666 -----------------------------------------------
eclipse.buildId=2020.1
java.version=9.0.4
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2020-10-06 20:58:04.661
!STACK 1
at com.xilinx.ide.application.ui.ide.ChooseWorkspaceWithRestoreDialog.createDialogArea(ChooseWorkspaceWithRestoreDialog.java:45)
at com.xilinx.ide.application.ui.Application.promptForWorkspace(Application.java:272)
at com.xilinx.ide.application.ui.Application.checkInstanceLocation(Application.java:188)
at org.eclipse.equinox.launcher.Main.main(Main.java:1471)
Basically at launch the splash screen disappear without the window. Then in top I could see java consuming 100% of a single core for 10 minutes before crashing and throwing this error message log.
It appears the problem is resolved by deleting the preference folder. /home/username/.Xilinx/Vitis
