Vitis2020.2 running custom AXI-Lite IP makefile gives error
In https://www.xilinx.com/support/answers/75527.html  referred to https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/Create-IP-AXI4-Lite/td-p/1139280 there is a solution by replacing code in makefile file in custom_ip driver. (It is referred to a custom IP build in Vivado HLS)
I have a basic Vivado 2020.2 project (Microzed 7020 board) with a AXI_Lite peripheral IP without adding any code. Vitis gives error when building the platform. Without this custom IP is OK.
I have been trying replacing the code in makefile but doesn't work.
I hope somebody can help me to find a solution to this issue..
This works: 1º replacing makefile code, 2º export hardware from Vivado 3º launch vitis and build again platform.
Thank you
Thank you
Unfortunately, after buliding the platform succesfully.
Running the simple helloworld app the execution fails.
Looking at BSP settings after changing the makefiles I notice the stdin, stdout has changed from default uart1 to uart0.
Any suggestion would be appreciated
Steps to get through it:
1 create platform 2 Change if need the BSP settings from  UART0 to UART1 3 Replace makefiles of the custom IP
4 Create App 5 Build the whole system 6 Run as hardware: Hello world is working now
