Vivado 2013.4 .MSS and _bsp not updated , .xml is OK
Hi ,
I have include in my video chain the scaler IP from Xilinx .
My HW is correctly synthesized , implemented and the bit file generated .
I export the HW to SDK  , and I see that the the system.xml file is correctly updated , the scaler IP has now a range of adresses  But the "system.mss" is not updated and I can't see the scaler's drivers files   in the libsrc folder(see attached file )  .
If I have a look in the parameter.h , I have no trace of the scaler . I have clean the project and rebuilt it but these file/folder are not updated . What is wrong ?
Thanks in advance .
Alex
Re: Vivado 2013.4 .MSS and _bsp not updated , .xml is OK
Please check when configuring the BSP to make sure that the scalar IP driver is assigned.
Go to SDK --> Xilinx Tools --> Board Support Package Settings --> Select the BSP --> Overview --> drivers --> select the driver for scaler IP.
Refer to the snapshot for reference
--Hem
