Scholar wzab
Vivado 2015.4 - Generated AXI4 peripherial with Master interface causes error "[Synth 8-403] loop limit (65538) exceeded" (wrong clogb2 implementation)
I wanted to create a simple AXI4 Peripheral to be used a base for tests and further development.
I've selected "Create and package IP", then "Create a new AXI4 Peripheral" and in section "Add interfaces" I've added one slave interface and one master interface.
The peripheral worked perfectly for small number of Master Interface transactions (parameter C M00 AXI TRANSACTIONS NUM in the customization GUI).
However, later I wanted to use it to test transfer of bigger sets of data, and I increased the number of transactions to 1048576.
This resulted in the following compilation error:
 [Synth 8-403] loop limit (65538) exceeded [".../sources_1/bd/top/ipshared/user.org/wzab_ip_ms_v1_0/hdl/wzab_ip_ms_v1_0_M00_AXI.vhd":104]
[Synth 8-421] mismatched array sizes in rhs and lhs of assignment [".../sources_1/bd/top/ipshared/user.org/wzab_ip_ms_v1_0/hdl/wzab_ip_ms_v1_0_M00_AXI.vhd":123]
I checked the sources and found that the problem is associated with the strange implementation of the clogb2 function:
   -- function called clogb2 that returns an integer which has the
    -- value of the ceiling of the log base 2
    function clogb2 (bit_depth : integer) return integer is
         variable depth  : integer := bit_depth;
         variable count  : integer := 1;
     begin
          for clogb2 in 1 to bit_depth loop  -- Works for up to 32 bit integers
          if (bit_depth <= 2) then
            count := 1;
          else
            if(depth <= 1) then
                count := count;
              else
                depth := depth / 2;
              count := count + 1;
              end if;
            end if;
       end loop;
       return(count);
     end;
   Basing on the decscription, that it should return the ceiling of the log2, I ve prepared equivalent, but much simpler implementation, which works correctly even for bigger arguments:
    variable depth : integer := 1;
  begin
    count := 0;
    while depth < bit_depth loop
      count := count + 1;
      depth := depth * 2;
    end loop;
    return(count);
  end;
I have successfully tested the above solution with 4MB transfers (1024*1024 32-bit transactions).
Wojtek
