02-08-2017 10:49 AM
I am attempting to migrate a Vivado project from 2015.2 to 2016.4. After finally getting the project to build, I export hardware (including bitstream) and open SDK. From SDK (and from the .sdk directory), I can see that there is no .mmi file. Previously, in 2015.2, this file was being created automatically. Is there an option for this? What is missing?
02-09-2017 09:28 AM
This issue has been resolved. I tracked the problem down to the LMB BRAM Controller IP in the Microblaze local memory sub-block of my block diagram. The LMB BRAM High Address didn't automatically update after changing the address range in the address editor.
To fix this, I changed the address range back and forth, disconnected/reconnected some nets in the local memory sub-block and eventually the address field updated. After rebuilding and exporting hardware, SDK now makes the .mmi file.
02-08-2017 01:55 PM
More info:
-After doing File->Export->Export Hardware from Vivado, a .sdk directory is created within project directory. The .sdk directory now has toplevel.hdf and nothing else.
-After doing File->Launch SDK from Vivado, the .sdk directory looks like this:
.metadata/ (contents not shown here for brevity)
RemoteSystemsTempFiles/
.project
toplevel_hw_platform_0/
.project
system.hdf
toplevel.bit
SDK.log
toplevel.hdf
02-09-2017 09:28 AM
02-09-2017 09:34 AM
And, apparently, Validate Design would have fixed this.
