jdefields
Vivado 2017.1 / 2017.2: PCIe configuration
Can someone screenshot (or point to a vivado developers guide) how PCIe should be configured in Vivado for a zynqmp?  ZCU102 example would be fine.
I'd like to know what the base settings for PCIe as a 'Root Port' should be.  Default class code is showing up as 0x058000 which is definitely wrong (I believe it should be 0x060400).  And even changing that, I get further but am still having issues during Linux
Justin D.
jdefields
@hbucher, I've seen that one already, but thanks for assisting. That guide doesn't list Bar0 setup, but I think we have it setup already correctly (at least for our current needs)
I actually resolved our specific issue. HW engineer had inverted polarity buffer going to PEX PCIe switch. I inverted the MIO reset line going to the switch to compensate.
hbucher
@jdefields Here
https://www.xilinx.com/video/hardware/create-pci-express-design-ultrascale-fpga.html
Hope this helps.
jdefields
@hbucher, That's for a soft PCIE core for the PL.
Zynqmp has a hard PCIE core in the PS section.  I'm looking for the configuration for that.
Justin D.
hbucher
@jdefields
Perhaps this should help
https://www.xilinx.com/support/documentation/application_notes/xapp1289-dma-pcie.pdf
jdefields
