xlpenglearing
Vivado 2018.1 SDK - "error launching program: for input string: '1e+08'
when I downloading *.elf in SDK environment,the sdk show the error. How to solve it???
xlpenglearing
Listen to me, I solved this problem.
I find all clock related modules ,such as:
Then,Open the axi_aclk. you will find a error in it.
changed the 1e+08 to 100.
The problem will be been solved.
derekm_
Hi, @xlpenglearing, you need to share your code to get help with this. Use the "Insert/Edit code sample" feature, as shown:
Also, please supply more details on your project (e.g. take a screen shot of the IP Integrator block diagram), tell us what board you are using, boot-mode settings, etc. Does this just happen with one project, or can you get other simple projects to work? Etc, etc.... Thanks!
xlpenglearing
My question is very similar to the one on the website (https://forums.xilinx.com/t5/Embedded-Development-Tools/Vivado-2019-1-3-SDK-quot-error-launching-program-for-input/m-p/1089277)
I just add a system_ila to debug code. In PL program ,I can download .when I use SDK to download *.elf code ,it show  the problem.
some body said the sdk not suppot 1e+08 expression, but In My program,I can not the 1e+08u code . so how the solve the problem?图片1.png
marcb
Hi @xlpenglearing
Does the below Forums post help? In one case, having the mode pins incorrect has lead to this error.
https://forums.xilinx.com/t5/Embedded-Development-Tools/Error-while-launching-program-For-input-string-quot-5e-07-quot/m-p/968639#M48980
stephenm
I think the BSP is failing here as the clock is getting incorrectly defined in the xparameters.h file. Can you add the HDF please?
xlpenglearing
This web site:https://forums.xilinx.com/t5/Embedded-Development-Tools/Error-while-launching-program-For-input-string-quot-5e-07-quot/m-p/968639#M48980
It can not solve my problem. MY PL program can be download to FPGA . But use SDK,It is show error.
xlpenglearing
Have other people encountered similar problems?
 I add the hdf,but,It still error.
so ,I update the vivdao2018.1 to  2019?or2020 version?
xlpenglearing
