Vivado and Vitis projects in relation with version control
I am newbie in Xilinx Vivado and Vitis tools and in the time being I am at the beginning of a project where I will use both the aforementioned tools. Among other stuff I have been looking for:
01) what is the recommended directory structure as far as Vivado and Vitis projects
02) how to appropriatelly use version control system (in my case Mercurial) for Vivado and Vitis projects
Can anybody share its experience? I would very appreciate an example of proven workflow. Thanks in advance for any comments.
I have spent some time and I have hit following Xilinx video . This video answers my question regarding the Vivado software.
1a) Recommended directory structure of Vivado project:
Working_directory - contains the .xpr file of Vivado project
Testbenches
Scripts
RTL
IPI_BDs - contains IP block designs
IP - contains IP blocks
HLS
DSP
Doc
Constraints
2a) Recommended approach as far as version control system usage for Vivado projects:
Recommendation is to check-in the .xpr file and optionally the whole IP directory.
Little bit different information can be found in UG892 (page 89 regards the project directory structure and page 85 regards what files have to be under version control system management).
As far as Vitis software.
2b) Recommended approach as far as version control system usage for Vitis projects:
Based on this answer it seems to me that the source files and the tcl script have to be under version control system management.
Testbenches
Scripts
RTL
HLS
DSP
Doc
Constraints
