Volatile signals from custom IP block in vivado SDK
Hi all
I am creating a costum IP block in vivado HLS, in which I have declared a input signal vector as volatile, because I want to access this vector multiple times. This is the headline of my function:
void detector_hw(AXI_STREAM& INPUT_STREAM, AXI_STREAM& OUTPUT_STREAM, int cols, int rows, volatile unsigned int features[9])
#pragma HLS INTERFACE bram depth=9 port=features
#pragma HLS RESOURCE variable=feature core=RAM_1P_BRAM
#pragma HLS INTERFACE s_axilite port=rows bundle=bus_control
#pragma HLS INTERFACE s_axilite port=cols bundle=bus_control
#pragma HLS INTERFACE s_axilite port=return bundle=bus_control
#pragma HLS INTERFACE axis port=INPUT_STREAM
#pragma HLS INTERFACE axis port=OUTPUT_STREAM
Additionally, I want save the different values of this vector (features) in the BRAM. How can I specify in te SDK program the change of memory address every time that my variable is updeted? I am new in vivado and I do not have a very clear idea of how to do it.
Thanks in advance!
Hi @metzli_12
The way of reading the variable is just using the same pointer that you provided to the accelerator, but the fact is that you don't have any way to syncrhonize your (PS) access with the IP accesses. At least that's my understanding.
Ibai
Ibai
Hi @metzli_12
I'm not really familiar with HLS so I might be missing somethin but I did not really understand your question... can you describe your issue/requirement better?
BTW: This is Embedded SDK board so you could have better feedback on the specific HLS forum board.
Ibai
Hi ibaie thank you very much for your answer.
Well, I already created my IP block using volatile data type with the objective to access multiple times to my variable "features" (here we can see a small explanation about volatile qualifier https://www.xilinx.com/support/answers/60434.html ), and my IP block seems to be working well. My question is about how to read this variable in vivado SDK? Is there any flag or register that tells me when my variable is updated or ready to be read? or how can I access this variable at each time it is updated?
I hope you can help me, because I don't find a lot information about this.
Thank you again.
Hi @metzli_12
Thanks for the clarification. I just did a quick search in the UG902 regarding the multi-access pointers and as my suspect has been confirmed with in the following statement.
Even this C code is problematic. Using a test bench, there is no way to supply anything but
a single value to d_i or verify any write to d_o other than the final write. Although
multi-access pointers are supported, it is highly recommended to implement the behavior
required using the hls::stream class. Details on the hls::stream class are in HLS
Stream Library in Chapter 2.
I mean although HLS by itself allows you to perform a multiple access to the pointer there is no way to indicate/flag/... the processor on each access just to allow to modify it during IP execution.
Again, not an expert on HLS but I think that the documentation is clear on it.
Ibai
Ibai
I had already read that information, but I supposed that if vivado offer the possibility of use volatile variables,then there must be a reliable way to read/write them in vivado SDK.
Thanks a lot for your time and patience.
Hi @metzli_12
Ibai
Ibai
