Visitor vibhuthk
WARNING:EDK:878 - Could not find IP doc
while runnimg DRC i am getting this warning.
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=proc_sys_reset;v=v3_00_a;d=proc_sy
   s_reset.pdf
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=lmb_v10;v=v2_00_b;d=pg087-lmb-v10.
   pdf
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=lmb_bram_if_cntlr;v=v3_10_c;d=pg06
   1-lmb-bram-if-cntlr.pdf
   pdf
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=bram_block;v=v1_00_a;d=bram_block.
   pdf
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=mdm;v=v2_10_a;d=pg062-mdm.pdf
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=clock_generator;v=v4_03_a;d=clock_
   generator.pdf
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=axi_interconnect;v=v1_06_a;d=ds768
   _axi_interconnect.pdf
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=axi_uartlite;v=v1_02_a;d=axi_uartl
   ite_ds741.pdf
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=axi_quad_spi;v=v2_00_b;d=ds843_axi
   _quad_spi.pdf
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=axi_gpio;v=v1_01_b;d=ds744_axi_gpi
   o.pdf
   o.pdf
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=axi_iic;v=v1_02_a;d=axi_iic_ds756.
   pdf
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=axi_ethernetlite;v=v1_01_b;d=ds787
   _axi_ethernetlite.pdf
   o.pdf
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=axi_7series_ddrx;v=v1_08_a;d=ug586
   _7Series_MIS.pdf
   http://www.xilinx.com/cgi-bin/docs/ipdoc?c=fsl_v20;v=v2_11_f;d=fsl_v20.pdf
   pdf
   pdf
   pdf
   pdf
   pdf
   pdf
   pdf
   pdf
   pdf
i am using 14.7 xilinx EDK
Community Manager
Community Manager
Re: WARNING:EDK:878 - Could not find IP doc
This is looking for the corresponding pg and datasheets for the IP peripherals and for some reason it is unable to find it.
You can safely ignore this warning and go ahead with your design implementation.
Sikta
Community Manager
Community Manager
Sikta
Documentation do not find warnings don't impact design functionality.
As a designer when ever you see any warning/critical warning try to find out if it contains any of your design elements and analyze its source, if you think it effects your design/placement/routing/timing then feel free to report else you can supress them or just ignore.
