Visitor shaker18
What's the problem with Packet Capture (using libpcap) in XPS ?
Hi everybody,
I'm working on an ML505 xilinx card and I try to use it for the capture of packets in network.
I have the famous code source of packets capture witch includes the "libpcap" librairy, I didn't find problems in understanding it or compiling it in Visual Studio or Devcpp ... but the problem is when I want to build in XPS a project witch uses this code as a source and the pcap.h as a header, I obtained those errors :
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/UDPdump/src/udpdump.c: In function 'main':
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/UDPdump/src/udpdump.c:188: error: dereferencing pointer to incomplete type
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/UDPdump/src/udpdump.c: In function 'packet_handler':
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/UDPdump/src/udpdump.c:244: warning: assignment makes pointer from integer without a cast
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/UDPdump/src/udpdump.c:245: warning: incompatible implicit declaration of built-in function 'strftime'
make: *** [microblaze_0/code/hello.elf] Error 1
Done!
You see well that those errors are in relation with the code witch is completely true !!
I even tried to eliminate those lines :smileyhappy: or to shorten the code and I found new errors in relation with libpcap !!! :
/cygdrive/c/DOCUME~1/Gondi/LOCALS~1/Temp/cc4zLX4L.o: In function `main':
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:124: undefined reference to `pcap_findalldevs'
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:150: undefined reference to `pcap_freealldevs'
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:163: undefined reference to `pcap_open_live'
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:171: undefined reference to `pcap_freealldevs'
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:171: undefined reference to `pcap_datalink'
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:180: undefined reference to `pcap_freealldevs'
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:183: undefined reference to `pcap_compile'
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:194: undefined reference to `pcap_freealldevs'
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:194: undefined reference to `pcap_setfilter'
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:203: undefined reference to `pcap_freealldevs'
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:205: undefined reference to `pcap_freealldevs'
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:209: undefined reference to `pcap_loop'
/cygdrive/c/DOCUME~1/Gondi/LOCALS~1/Temp/cc4zLX4L.o: In function `packet_handler':
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:247: undefined reference to `ntohs'
/cygdrive/c/ml505_bsb_std_ip/sw/standalone/hello/src/hello.c:252: undefined reference to `ntohs'
collect2: ld returned 1 exit status
Done!
Any one who know the answer ? I need a help.
Visitor shaker18
Re: What's the problem with Packet Capture (using libpcap) in XPS ?
I don't know if I should give you the source code ...
#define HAVE_REMOTE
#include <stdio.h>
#include <stdlib.h>
#include <errno.h>
#include <string.h>
#include "xparameters.h"
#include "pcap.h"
#include "memory_map.h"
/* 4 bytes IP address */
typedef struct ip_address
 u_char byte1;
 u_char byte2;
 u_char byte3;
 u_char byte4;
}ip_address;
/* IPv4 header */
typedef struct ip_header
 u_char ver_ihl;  // Version (4 bits) + Internet header length (4 bits)
 u_char tos;   // Type of service
 u_short tlen;   // Total length
 u_short identification; // Identification
 u_short flags_fo;  // Flags (3 bits) + Fragment offset (13 bits)
 u_char ttl;   // Time to live
 u_char proto;   // Protocol
 u_short crc;   // Header checksum
 ip_address saddr;  // Source address
 ip_address daddr;  // Destination address
 u_int op_pad;   // Option + Padding
}ip_header;
/* UDP header*/
typedef struct udp_header
 u_short sport;   // Source port
 u_short dport;   // Destination port
 u_short len;   // Datagram length
 u_short crc;   // Checksum
}udp_header;
typedef struct tcp_header
 u_long seq;    // sequence number
 u_long ack;    // acknowledgement number
 u_short doffset;  // data offset (4 bits) + reserved (6 bits) + flags (6 bits)
 u_short wind;   // window
 u_short check;   // checksum
 u_short urgptr;   // urgent pointer
}tcp_header;
typedef struct connexion
 int dur;    // Duration
 time_t tstart;   // Time start
 int packets;   // Packet number
 //bool stat;    // Stat : connected or no;
 // duplication : 2nd connexion  !!!!
}connexion;
/* prototype of the packet handler */
void packet_handler(u_char *param, const struct pcap_pkthdr *header, const u_char *pkt_data);
void print_bin(char a);
int nb=0;
main()
 pcap_if_t *alldevs;
 pcap_if_t *d;
 int inum;
 int i=0;
 pcap_t *adhandle;
 char errbuf[PCAP_ERRBUF_SIZE];
 u_int netmask;
 char packet_filter[] = "ip and tcp";
 struct bpf_program fcode;
 /* Retrieve the device list */
 if(pcap_findalldevs(&alldevs, errbuf) == -1)
  fprintf(stderr,"Error in pcap_findalldevs: %s\n", errbuf);
  exit(1);
 /* Print the list */
 for(d=alldevs; d; d=d->next)
  printf("%d. %s", ++i, d->name);
  if (d->description)
   printf(" (%s)\n", d->description);
  else
   printf(" (No description available)\n");
 if(i==0)
  printf("\nNo interfaces found! Make sure WinPcap is installed.\n");
  return -1;
 printf("Enter the interface number (1-%d):",i);
 scanf("%d", &inum);
 /* Check if the user specified a valid adapter */
 if(inum < 1 || inum > i)
  printf("\nAdapter number out of range.\n");
  /* Free the device list */
  pcap_freealldevs(alldevs);
  return -1;
 /* Jump to the selected adapter */
 for(d=alldevs, i=0; i< inum-1 ;d=d->next, i++);
 /* Open the adapter */
 if ((adhandle= pcap_open_live(d->name, // name of the device
        65536,   // portion of the packet to capture.
           // 65536 grants that the whole packet will be captured on all the MACs.
        1,    // promiscuous mode (nonzero means promiscuous)
        1000,   // read timeout
        errbuf   // error buffer
        )) == NULL)
  fprintf(stderr,"\nUnable to open the adapter. %s is not supported by WinPcap\n");
  return -1;
 /* Check the link layer. We support only Ethernet for simplicity. */
 if(pcap_datalink(adhandle) != DLT_EN10MB)
  fprintf(stderr,"\nThis program works only on Ethernet networks.\n");
  return -1;
 if(d->addresses != NULL)
  /* Retrieve the mask of the first address of the interface */
  netmask=((struct sockaddr_in *)(d->addresses->netmask))->sin_addr.S_un.S_addr;
 else
  /* If the interface is without addresses we suppose to be in a C class network */
  netmask=0xffffff;
 //compile the filter
 if (pcap_compile(adhandle, &fcode, packet_filter, 1, netmask) <0 )
  fprintf(stderr,"\nUnable to compile the packet filter. Check the syntax.\n");
  return -1;
 //set the filter
 if (pcap_setfilter(adhandle, &fcode)<0)
  fprintf(stderr,"\nError setting the filter.\n");
  return -1;
 printf("\nlistening on %s...\n", d->description);
 /* At this point, we don't need any more the device list. Free it */
 /* start the capture */
   pcap_loop(adhandle, 0, packet_handler, NULL);
 return 0;
/* Callback function invoked by libpcap for every incoming packet */
 struct tm *ltime;
 char timestr[16];
 ip_header *ih;
 udp_header *uh;
 u_int ip_len;
 u_short sport,dport;
 time_t local_tv_sec;
 tcp_header *th;
 connexion *con;
 int i,k=16;
 u_short a;
 //packets number
 nb++;
 /* convert the timestamp to readable format */
 local_tv_sec = header->ts.tv_sec;
 ltime=localtime(&local_tv_sec);
 strftime( timestr, sizeof timestr, "%H:%M:%S", ltime);
 printf("packet %d at :",nb);
 /* print timestamp and length of the packet */
 printf("%s.%.6d len:%d ", timestr, header->ts.tv_usec, header->len);
 /* retireve the position of the ip header */
 ih = (ip_header *) (pkt_data +
  14); //length of ethernet header
 /* retireve the position of the tcp (or udp) header */
 ip_len = (ih->ver_ihl & 0xf) * 4;
 //uh = (udp_header *) ((u_char*)ih + ip_len); //for udp header
 th = (tcp_header *) ((u_char*)ih + ip_len);  //for tcp header
 printf("protocol is: %.2x \n", ih->proto);
 /* convert from network byte order to host byte order */
 sport = ntohs( th->sport );
 dport = ntohs( th->dport );
 //printf("ack is : %.2x \n", th->ack);
 //printf("seq num is : %.2x \n", th->seq);
 a=th->doffset;
 printf("offset is : %.2x \n", a);
 for (i=k-1;i>=0;i--) {
  printf("%c",(a&(1<<i))?'1':'0');
 printf("\n");
 //print_bin(char th->doffset);
 /* print ip addresses and udp ports */
 printf("%d.%d.%d.%d/%d -> %d.%d.%d.%d/%d\n", //j'ai remplacé . par / pour les ports
  ih->saddr.byte1,
  ih->saddr.byte2,
  ih->saddr.byte3,
  ih->saddr.byte4,
  sport,
  ih->daddr.byte1,
  ih->daddr.byte2,
  ih->daddr.byte3,
  ih->daddr.byte4,
  dport);
