Where is the source for the examples listed in my BSP documentation?
I have created a basic "hello world" application and have it running on my microzed board perfectly. I even have minicom and the SDK's terminal window showing my "hello world" string. I'm wanting to move to a more custom UART driver and thought the best way is to have a look at the BSP specifically the driver called uartps_v3_7.
The above lists all the driver code but I wanted some documentation and examples. So I clicked on the BSP Documentation and then clicked on "uartps_v3_7" which popped open a page on my browser.
Like I said this brought up a page in my browser and gave me a file tree I could browse on the left. You guys really went above and beyond here maybe a bit too much cause I can't find the actual source code for the examples. You give me explanation after explanation of functions but I can't find the source code for the example itself?!? Am I blind and missing something here?
Re: Where is the source for the examples listed in my BSP documentation?
HI @scy86dev ,
The source is not imported in the BSP. However you can import the example from the BSP.
Open the system.mss file in your BSP. Inside you can click on open example for the peripheral you want:
Florent
