liwenz
Why SDK 2018.2 always exit
My Vivado and SDK 2018.2 worked fine. But recently, I want to try the udp server example include  in sdk.
It let me choose the work folder then quit and show nothing.
I tried start from Vivado, And it also quit after a moment.
Why? the udp demo issue?
glena
Do you see this behavior in all SDK workspaces or only 1?  I suspect a corrupt workspace, delete the offending workspace and create a new one.   You could also try deleting the .metadata folder in the corrupt workspace and rebuild from there.
liwenz
I only notepad++ open the main.c and close and find nothing. Then I open the project.
The project is only a udp server example.
I find the sdk 18.2 is easy to down.
etl17
Hi glena,
I also experience a similar issue with the latest 2018.2.2 SDK on Windows 10.
It is definitely not related to the specific workspace. It is easily reproducible with new workspace and/or projects.
Best,
--Stefanos
rajut
Please do the windows update periodically, there might be some compatible issues with the old version of OS libraries. We always do updates to our PCs with Windows Update and we haven't seen any crash.
Please update your PCs and let us know whether you are still seeing the crash.
Raju
