Why UART don't send buffer ?
I can't see how to operate the axi uart for sending only.
There is no interrupt for SendDataHandler(), when trying to send buffer.
I based my code on "xuartns550_intr_example.c" and when I comment out the xxx_recv() routine, I get no interrupt in sending. Without this comment out, the send interrupt works just fine.
Why does the uart transmit depends on reception ? I only want to test transmit - nothing else. In theory there should not be any dependency between sending and receiving,
Thank you for any comments,
Ran
Re: Why UART don't send buffer ?
I'll check with development team regarding this behavior. Please hold on till then.
Praveen
Thank you very much,
I am looking forward for understanding this issue.
Best Regards,
Ran
This is already an enhancement request made for the driver functionality.
Praveen
Hi Praveen,
I'm not sure I understand.
Do you mean that currently this is not possible to send buffers, without waiting and receiving bytes on reciever ?
Why there is such dependency ?
What should I do if there is no receiving , does the senfinf will fail in such case ?
Thank you,
Ran
