Why does SDK include libsrc/iic_v3_1 while the HW uses axi_iic:2.0?
I included the axi_iic:2.0 in VIvado 2015.4 with Zynq board.
However after generating bit stream and export hardware into SDK, when I create a single hello_world standard alone application project iic_test, a iic_test_bsp is created and include iic_v3_1 in the libsrc directory.
The AXI register map is different from the pg090-axi-iic.pdf.
Why is the discrepancy? Is the version number 3.1 in libsrc/iic_v3_1 meant for axi_iic:3.1?
