Observer snowolfyou
Why doesn't XHwIcap_StartReadBack(hwicap) work?
hi,
Does anyone know of some sample code that shows how to use an ICAP controlled by a Microblaze to read back of a partial module's bitstream?
  I have been pulling my hair out trying to make the XHwIcap_StartReadBack(hwicap) function work properly. XHwIcap_GetControlReg(hwicap) tell me that the CR value is 0, not 2.
But at the same time, the XHwIcap_StartConfig(hwicap) function work properly, XHwIcap_GetControlReg(hwicap) tell the CR set right.
This means that the XHwIcap_StartReadBack(hwicap) function does't work. Could you tell me how can make it work properly?
best regards,
snowolfyou
Re: Why doesn't XHwIcap_StartReadBack(hwicap) work?
There are some examples located in the install directory e.g.
C:\Xilinx\13.x\ISE_DS\EDK\sw\XilinxProcessorIPLib\drivers\hwicap_v6_00_a\examples
xhwicap_read_frame_polled_example.c shows an example of reading configuration information
Observer snowolfyou
I follow these example. but the value of reading back are "0".
my program is :
 Status = XSysAce_Initialize(&SysAce, XPAR_SYSACE_0_DEVICE_ID);
 if (Status != XST_SUCCESS) {   return XST_FAILURE;  }
 print("System ACE Controller Initialized\r\n");
  ConfigPtr = XHwIcap_LookupConfig(XPAR_XPS_HWICAP_0_DEVICE_ID);
 if (ConfigPtr == NULL) {   return XST_FAILURE;  }  print("After HWICAP LookupConfig\r\n");
 Status = XHwIcap_CfgInitialize(&HwIcap, ConfigPtr,     ConfigPtr->BaseAddress);  if (Status != XST_SUCCESS) {   return XST_FAILURE;  }  print("HWICAP Initialized\r\n");
 Status = XHwIcap_DeviceReadFrame(&HwIcap,        HWICAP_EXAMPLE_TOP,        HWICAP_EXAMPLE_BLOCK,        HWICAP_EXAMPLE_HCLK,        HWICAP_EXAMPLE_MAJOR,        HWICAP_EXAMPLE_MINOR,        (u32 *) &FrameData[0]);
     for (i=0;i<83;i++){          xil_printf("word %d= %0x\r\n",i,FrameData[i]);      }
The value got are 0.
I dont the reason. Who will tell me ?
Hello.Did your problem has been solved ?
