Write 1M data to Compact Flash
I have a LX110T virtex5 board with sysace controller, and i  can write a file to the compact flash, but the data i write is small,i only can write 80k datas to CF card one time.now i want write 1M date to CF card.
1.What should I do?if i want to write 1M date to CF card.
2.Can anyone tell me if I can use sysace_fwrite without erasing the existing contents of the file? I know sysace_fopen only has two modes, "r" or "w", but shouldn't there be a mode to avoid erasing the contents of the existing file and "append" a new string like the "a" mode of fopen in C?
Best,
HCL
Re: Write 1M data to Compact Flash
i fix it.ok now
I am trying to do the same on a ML605 board. I want to Read/write files from compact flash. But for some reason , my file open always returns a failure. Do you know if there is any reference design available from Xilinx? I have attached my code below :
#include <string.h>
#include "sysace_stdio.h"
int main()
	xil_printf(" Hello \n");
	const char *file="paul.txt";
	const char*mode="r";
	SYSACE_FILE *ps;
	ps=sysace_fopen (file, mode);
	if(ps==NULL)
		xil_printf(" FILE OPEN FAILED !!! \n");
	else
		xil_printf(" FILE OPEN SUCCESSFULL !!! \n");
		int sysace_fclose (ps);
	return 0;
This is a validated and tested reference design provided by Xilinx.
http://www.xilinx.com/support/documentation/boards_and_kits/xtp056.pdf
Type C test will help you perform a test on your CF card via system ACE.
--Hem
Thanks for the reply.
I have tested the board using compact flash. However, I would like to store some information in a text file using microblaze design. I would like to know if there is any reference design for to store data in compact flash?
Paul
Can you try the lab mentioned here? This might be an older link but the procedure is relavent.
--Hem
Thanks for the reply again.
I saw this material and there are some issues with that lab material:
1. The tutorial do not describe the hardware settings of the project
2. Couple of namely ReadText.c, StackAndHeap.h & StackAndHeap.c are not avaliable to general users.
Here is a summary of my project:
1. Created an XPS project and added compact flash IP to the microblaze design
2. Generated bitstream and exported the design to SDK
3. Created a new software project - added the Libxil FAT system library
4. Wrote a C code to open a file
Problems faced:
1. The fileopen function was returning a failure both in "r" or "w" mode.
2.  I am still not clear about the jumper settings. ( in the ML605 userguide, it shows one settings but xilinx reference design -built in self test reference design shows another settings.
I debugged the code a little more. I found that there is a lock forced by either microblaze or controller.
The code returns a XST_DEVICE_BUSY( as per SDK documentation  return  XST_DEVICE_BUSY if the lock was not granted because the configuration controller currently has access to the CompactFlash.").
This suggests that the initialization of SYSTEM ACE for reading/writing is not done properly.
Anyone has any idea why this happens???
Paul
My problem is solved. This was because I formatted the flash card.
I restored contents of the orginal design and then it worked fine.
Thank you.
Hi can someone help me about opening a compact flash file in xilinx sdk.
I am using xilinx 13.1 and xupv5-lx110T board.
My doubt is,
If the file doesnt exist in compact flash, and if I open file in write mode, will the file be created?
In any case even if I open the file in read mode (after formatting the compact flash and creating the file), the file pointer is always returning NULL in both read mode and write mode.
Do I have to change DIP settings for programming mode in SDK for compact flash. I tried the above program putting DIP setting in default configuration.
int main()
    xil_printf("\n\r Hello \n\r");
    const char *file="test.txt";
    const char*mode="w";
    SYSACE_FILE *ps;
    if(ps==NULL)
        xil_printf(" FILE OPEN FAILED !!! \n\r");
    else
        xil_printf(" FILE OPEN SUCCESSFULL !!! \n\r");
        sysace_fclose (ps);
    return 0;
Can someone please help this issue.
Did you change to software setting of application to include write support. The following link might also help:
http://ideaprojecthardware.blogspot.ca/2014/04/writingreading-data-from-compact-flash.html
