ahmed_alfadhel
Writing My own code in XSDK
Hi ,
I attached a copy of my design .
I exported the design to XSDK. Then created a new project with Peripheral Tests Template.
The question is : where I have to add my own code , does it in testperiph.c  or in main.c ?
Thanks in advance
jribeiro_mog
you need to add your code in testperiph.c file, as it is in the application project that you will be able to run in the board.
The main.c you highlighted is part of an example generated alongside the files describing the hardware you implemented (hw_platform) and is an example of the main file could look like.
Best regards
jribeiro_mog
Best regards
