Voyager
Voyager
Wrong MIG name exported to SDK
Hi, i use a MIG with 2 controllers. When i export the hardware to SDK, in the xparameter.h i have only the address of the first controller.
In the linker script i see that the names for the two controllers are the same. I manually renamed one of that, but is there a different procedure?
Re: Wrong MIG name exported to SDK
hi,
this issue is reported to the factory for further investigation and will be fixed in the future reelase.
--hem
Scholar sampatd
Which version of the tool do you use?
Also, how does the entree in xparameters.h file look like?
Voyager
Voyager
Thank you for your reply,
version is Vivado 2014.4 , in the xparameters only 1 address ( 0x88000000) is present
/* Definitions for driver MIG_7SERIES */
#define XPAR_XMIG7SERIES_NUM_INSTANCES 1
/* Definitions for peripheral MIG_7SERIES_DDR3 */
#define XPAR_MIG_7SERIES_DDR3_DEVICE_ID 0
#define XPAR_MIG_7SERIES_DDR3_DDR3_ROW_WIDTH 13
#define XPAR_MIG_7SERIES_DDR3_DDR3_COL_WIDTH 0
#define XPAR_MIG_7SERIES_DDR3_DDR3_BANK_WIDTH 3
#define XPAR_MIG_7SERIES_DDR3_DDR3_DQ_WIDTH 16
#define XPAR_MIG_7SERIES_DDR3_BASEADDR 0x88000000
#define XPAR_MIG_7SERIES_DDR3_HIGHADDR 0x8FFFFFFF
/* Canonical definitions for peripheral MIG_7SERIES_DDR3 */
#define XPAR_MIG7SERIES_0_DEVICE_ID XPAR_MIG_7SERIES_DDR3_DEVICE_ID
#define XPAR_MIG7SERIES_0_DDR_ROW_WIDTH 13
#define XPAR_MIG7SERIES_0_DDR_COL_WIDTH 0
#define XPAR_MIG7SERIES_0_DDR_BANK_WIDTH 3
#define XPAR_MIG7SERIES_0_DDR_DQ_WIDTH 16
#define XPAR_MIG7SERIES_0_BASEADDR 0x88000000
#define XPAR_MIG7SERIES_0_HIGHADDR 0x8FFFFFFF
hi,
xparameters.h seems to be fine. if you are able to access your memory and execute any application from DDR, then we would need the hdf/xml to check if this is a problem with the GUI.
if MSS also shows one instance of DDR then it might be SDK reporting two instances. But i would like to investigate this further.
--hem
hi,
--hem
