Visitor sraxlz
XEN build error in PetaLinux 2016.4 for Zynq UltraSCALE+ MPSoC
Environment: Ubuntu 16.04 (LTS) host, PetaLinux 2016.4, Zynq UltraSCALE+ MPSoC.
Command being executed: petalinux-build -c xen-image-minimal
Getting XEN build errors related to util-macros-1.19.0, xtrans-1.3.5, and xproto-7.0.28. It keeps failing trying to get these from xorg.freedesktop.com.
Any help is kindly appreciated.
Thank you.
Re: XEN build error in PetaLinux 2016.4 for Zynq UltraSCALE+ MPSoC
Are you able to clone those repos individually on command prompt ?.
Something related to your company IT security.
Alternatively you can point mirrors in petalinux-config --> Yocto settings -->  YOCTO SOURCE MIRROR URL
choose external path
enter  http://www.petalinux.xilinx.com/sswreleases/rel-v2016.4/downloads
let us know ..
Visitor sraxlz
Thanks for the reply!
I tried this suggestion, but it still errors out. Is this URL still valid? I ran wget for one of my needed packages from this URL, but it refused connection.
Is there an updated URL from Xilinx to download needed packages?
Regards.
i am sorry the link is not available for 16.4.
It is avaialable from 17.1+
so, in 16.4 download the  sstate tar file and use, the instructions are already in the tar file
 sstate cache (TAR/GZIP - 14.56 GB)
MD5 SUM Value:4a848d98c1b6546592a0178f29702c71
Visitor fastian12
I am trying to build the virtualization support on Zynqmp Ultrazed board.  I have taken these steps so far:
  • Using the filesystem from pre-built images provided in the petalinux 2017.1 and copied in partition2 of the sd card
  • Created the kernel and u-boot using the petalinux 2017.1 (placed in the boot partition along with the boot.bin, system.dtb, Image, xen.ub, uEnv.txt)
  • Controlling u-boot environment variables using the uEnv.txt
  • Added the following uboot related parameters:
    • load mmc 1:1 $fdt_addr system.dtb && load mmc 1:1 $kernel_addr Image; fdt addr $fdt_addr && fdt resize 128 && fdt set /chosen \#address-cells <1> && fdt set /chosen \#size-cells <1> && fdt mknod /chosen dom0 && fdt set /chosen/dom0 compatible "xen,linux-zimage" "xen,multiboot-module" && fdt set /chosen/dom0 reg <0x80000 0x$filesize> && fdt set /chosen xen,xen-bootargs "console=dtuart dtuart=serial0 dom0_mem=512M bootscrub=0 maxcpus=1 timer_slop=0" && fdt set /chosen xen,dom0-bootargs "console=serial0 earlycon=xen earlyprintk=xen maxcpus=1 clk_ignore_unused root=/dev/mmcblk0p2"; load mmc 1:1 6000000 xen.ub; bootm 6000000 - $fdt_addr
when I boot the system I get this dump and ‘XEN’ gets not started:
reading system.dtb
27884 bytes read in 20 ms (1.3 MiB/s)
reading Image
13369856 bytes read in 979 ms (13 MiB/s)
libfdt fdt_add_subnode(): FDT_ERR_EXISTS
reading xen.ub
721280 bytes read in 63 ms (10.9 MiB/s)
## Booting kernel from Legacy Image at 06000000 ...
   Image Name:
   Image Type:   AArch64 Linux Kernel Image (uncompressed)
   Data Size:    721216 Bytes = 704.3 KiB
   Load Address: 05000000
   Entry Point:  05000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 04000000
   Booting using the fdt blob at 0x4000000
   Loading Kernel Image ... OK
   reserving fdt memory region: addr=4000000 size=7000
   Loading Device Tree to 0000000007ff6000, end 0000000007ffffff ... OK
Starting kernel ...
Xen 4.8.1-pre
(XEN) Xen version 4.8.1-pre (xbrbbot@) (aarch64-xilinx-linux-gcc (Linaro GCC 6.2-2016.11) 6.2.1 20161016) debug=n  Tue Apr 25 02:03:32 MDT 2017
(XEN) Latest ChangeSet: Sun Mar 26 23:37:13 2017 +0200 git:ba8ea4d-dirty
(XEN) Processor: 410fd034: "ARM Limited", variant: 0x0, part 0xd03, rev 0x4
(XEN) 64-bit Execution:
(XEN)   Processor Features: 0000000000002222 0000000000000000
(XEN)     Exception Levels: EL3:64+32 EL2:64+32 EL1:64+32 EL0:64+32
(XEN)     Extensions: FloatingPoint AdvancedSIMD
(XEN)   Debug Features: 0000000010305106 0000000000000000
(XEN)   Auxiliary Features: 0000000000000000 0000000000000000
(XEN)   Memory Model Features: 0000000000001122 0000000000000000
(XEN)   ISA Features:  0000000000011120 0000000000000000
(XEN) 32-bit Execution:
(XEN)   Processor Features: 00000131:00011011
(XEN)     Instruction Sets: AArch32 A32 Thumb Thumb-2 Jazelle
(XEN)     Extensions: GenericTimer Security
(XEN)   Debug Features: 03010066
(XEN)   Memory Model Features: 10201105 40000000 01260000 02102211
(XEN)  ISA Features: 02101110 13112111 21232042 01112131 00011142 00011121
(XEN) Generic Timer IRQ: phys=30 hyp=26 virt=27 Freq: 100000 KHz
(XEN) GICv2 initialization:
(XEN)         gic_dist_addr=00000000f9010000
(XEN)         gic_cpu_addr=00000000f9020000
(XEN)         gic_hyp_addr=00000000f9040000
(XEN)         gic_vcpu_addr=00000000f9060000
(XEN)         gic_maintenance_irq=25
(XEN) GICv2: Adjusting CPU interface base to 0xf902f000
(XEN) GICv2: 192 lines, 4 cpus, secure (IID 0200143b).
(XEN) Using scheduler: SMP Credit Scheduler (credit)
(XEN) Allocated console ring of 16 KiB.
(XEN) Bringing up CPU1
(XEN) Bringing up CPU2
(XEN) Bringing up CPU3
(XEN) Brought up 4 CPUs
(XEN) P2M: 40-bit IPA with 40-bit PA
(XEN) P2M: 3 levels with order-1 root, VTCR 0x80023558
(XEN) I/O virtualisation disabled
(XEN) *** LOADING DOMAIN 0 ***
(XEN) Loading kernel from boot module @ 0000000000000000
(XEN) ELF: not an ELF binary
(XEN)
(XEN) ****************************************
(XEN) Panic on CPU 0:
(XEN) Could not set up DOM0 guest OS
(XEN)
(XEN) Reboot in five seconds...
Can anyone please let me know what is the issue.
