XIIC PS Master Send polled
Hi all
I want to be able to communicate with an IMU, the Sparkfyn LSM9DS1 (which is a slave device at address 0x6B), accessing it from the ZyBo.
When trying to write code to set up I2C communication with it, I want to be able to send data to it with XIicPs_MasterSendPolled function. However when accessing it, it always gets into an infinite loop when it is waiting for the FIFO to be empty.
I exported the signals to some ports (3.3LVCMOS pullup, ...) But I only get a high signal and no action, although I2C configuration & selftest were succesful.
- Why is it that the FIFO isn't being emptied?
- Should I normally lower the clock for the internal (Zynq PS) to get the I2C working? And if so how? (I2C should work at 100k, right now my FCLK is at 100MHz...)
- Is there a way to verify if the slave address I'm using is the correct one, as I've read at some places that sometimes you must alter it by shifting it...
My files: iic.c
#include "main.h"
#include "iic.h"
#include "sleep.h"
 * 									IicConfig()									*
 * Initialises the IIC driver by looking up the configuration in the config
 * table and then initialising it. Also sets the IIC serial clock rate.
unsigned char IicConfig(unsigned int DeviceIdPS)
	XIicPs_Config *Config;
	int Status;
	/* Initialise the IIC driver so that it's ready to use */
	// Look up the configuration in the config table
	Config = XIicPs_LookupConfig(DeviceIdPS);
	if(NULL == Config) {
		xil_printf("IIC lookup FAILED \r\n");
		return XST_FAILURE;
	// Initialise the IIC driver configuration
	Status = XIicPs_CfgInitialize(&Iic, Config, Config->BaseAddress);
	if(Status != XST_SUCCESS) {
		xil_printf("IIC config FAILED \r\n");
		return XST_FAILURE;
	 * Perform a self-test to ensure that the hardware was built correctly.
	Status = XIicPs_SelfTest(&Iic);
	if (Status != XST_SUCCESS) {
		xil_printf("IIC selftest FAILED \r\n");
		return XST_FAILURE;
	xil_printf("IIC Passed\r\n");
	//Set the IIC serial clock rate.
	Status = XIicPs_SetSClk(&Iic, IIC_SCLK_RATE);
		xil_printf("IIC setClock FAILED \r\n");
		return XST_FAILURE;
	return XST_SUCCESS;
 * 								IicWriteToReg									*
 * Function to write to one of the registers from the IMU
void IicWriteToReg(u8 u8RegAddr, u16 u16Data) {
	unsigned char u8TxData[2];
	u8TxData[0] = u8RegAddr << 1;
	u8TxData[0] = u8TxData[0] | ((u16Data >> 8) & 0b1);
	u8TxData[1] = u16Data & 0xFF;
	XIicPs_MasterSendPolled(&Iic, u8TxData, 2, LSM9DS1_GX_ADDR);
	while(XIicPs_BusIsBusy(&Iic));
int startIMU()
	xil_printf("reset  Gyr/Acc at address 6B (SDO_GX is tied high)\n");
	u16 device_addr = LSM9DS1_GX_ADDR;
	u8 buf[] = {0x22,0x08}; //0x22 Ctrl_Reg8 ==> 0x08 should be reset
	XIicPs_MasterSendPolled(&Iic, buf, 1, device_addr);
	xil_printf("reset done\n");
	return XST_SUCCESS;
main.c:
#include "main.h"
 * 									main()										*
 * Runs all initial setup functions to initialise the audio codec and IP
 * peripherals, before calling the interactive menu system.
int main(void)
	XStatus Status;
	xil_printf("Entering Main\r\n");
	//Configure the IIC data structure
	IicConfig(XPAR_XIICPS_0_DEVICE_ID);
	xil_printf("I2c configured\n\r");
	Status = startIMU();
		xil_printf("IMU hasn't started\n");
    return 1;
Lots of thanks!
Newbie maaxchen10
Re: XIIC PS Master Send polled
maybe you should modify the Bytecount in XilPs_MasterSendPolled from 1 to 2 ?
int startIMU()
	return XST_SUCCESS;
 I also try to connect MPU6050 to zc702 but still does not work, thank for your exsample code!
best regard :)
Visitor david.600
Did you solve his issue?
Tags (3)
