Visitor anp
XMD/Instruction Set Simulator (ISS) error with Microblaze and xps_timer
I would like to perform execution time estimates on the Microblaze softcore, and have planned to do this by using XMD with the instruction set simulator. I did:
1) Build a base system in XPS with Microblaze processor (no cache, 64 kb memory), xps_timer and interrupt controller
1.1)  Generate netlist and bitstream
2) Create a SW project with the code
#include "xparameters.h"
#include "xtmrctr.h"
XTmrCtr XPS_Timer;
Xuint32 startTime,finishTime,execTime;
int main() {
XTmrCtr_Initialize(& XPS_Timer, XPAR_XPS_TIMER_1_DEVICE_ID);
XTmrCtr_SetResetValue(& XPS_Timer, XPAR_TMRCTR_0_DEVICE_ID, 0x00000000);
XTmrCtr_Reset(& XPS_Timer, XPAR_TMRCTR_0_DEVICE_ID);
startTime=XTmrCtr_GetValue(& XPS_Timer, XPAR_TMRCTR_0_DEVICE_ID);
XTmrCtr_Start(& XPS_Timer, XPAR_TMRCTR_0_DEVICE_ID);
// Code to test
XTmrCtr_Stop(& XPS_Timer, XPAR_TMRCTR_0_DEVICE_ID);
finishTime=XTmrCtr_GetValue(& XPS_Timer, XPAR_TMRCTR_0_DEVICE_ID);
execTime=finishTime-startTime;
return 0;
2.1) Build application
3) Select XMD d
ebug options to "Simulator"
4) Start XMD
4.1) Download bitstream ("dow executable.elf")
4.2) Set breakpoint ("bps exit")
4.3) Run ("run")
I get the error:
RUNNING> XMD% D-OPB timed out for address: 0, PC: 834
This could arise due to any of the following reasons:
1. program accessing invalied memory
2. no peripheral mapped at the requested address
3. ISS error
This puzzles me as there is no OPB in my design. (I am aware that OPB is not supported for XMD/ISS)
The error occurs only when I use the XTmr functions, if I remove them the code executes fine.
Is it impossible to use a xps_timer in the instruction set simulator
Visitor stone9502
Re: XMD/Instruction Set Simulator (ISS) error with Microblaze and xps_timer
I am thinking maybe that's because the ISS, which doesn't support peripheral. When the program try to access the timer, it issue a time out error.
Visitor stone9502
I met the same problem with you.
I didn't use OPB in my design at all. It seems the simulator assume the timer use OPB instead of PLB  and the processor get no response from the OPB bus so encounter an error.
is that right?
stone
Visitor stone9502
Visitor anp
Yes, sorry for the long delay of the answer.
I have come to the same conclusion. ISS must see the xps_timer as a peripheral, thus it won't work. I have changed the setup to run MDM on a dev. board and load the elf-files with xmd. Then I can access the timer and other peripherals.
