silva83
XPS + Spartan 3E-500 Starter Board + MMU option
    I created a system design on BSB and I can't modify microblaze option to include MMU! :( How can I include this option on XPS!?...
centaur19
silva83,
Which version of the tools are you using? If it is post 9.2i, then you must be able to see the MMU tab when you right click on the Microblaze instance and select "Configure IP".
centaur19
silva83,
silva83
   I am using EDK10.1, and I see the window with MMU options, but I can't modify the parameters to use MMU!!! It's no MMU for default! Are you now How can I get permissions to be able to use it!?...
silva83
   I get it!! :)
