varunbaskar
XSA to HDF
Hello everyone,
I'm having an xsa file generated using Vivado 2019.2. I wish to convert it to hdf or generate a hdf file separately using other tools. I came across the petalinux tool. However, am not sure if it helps in the conversion process.
Is there a way to get the .hdf file?
Thanks for your help in advance.
nutang
Hi @varunbaskar
You can use below command in Vivado tcl console
write_hwdef -force C:/Data/ug940/lab1/zynq_design.hdf
Best Regards,
Nutan
varunbaskar
My mistake with the title. I edited it now. I wish to convert xsa to hdf. Is it the same command as you've mentioned?
nutang
Hi @varunbaskar
No, It will not convert xsa to hdf.
Please let me know in brief what is your end goal.
So I can help you.
Best Regards,
Nutan
varunbaskar
The xsdk version is 2016.2. Vivado in 2019.2. Unfortunately 2019.2 doesn't generate hdf file to be used by 2016.2 xsdk. It only generates xsa. So, i wish to convert xsa to hdf so it can be used by 2016.2 xsdk. I installed Vitis and tried to import the old xsdk project files from 2016.2. But it didn't work as Vitis just deleted those projects automatically.
nutang
Hi @varunbaskar
It is not recommended to use different versions of Vivado and SDK.
I would suggest downloading Vitis and follow the below SDK to Vitis migration guide.
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Step-By-Step-Guide-To-Xilinx-SDK-Project-Migration-To-Vitis/ba-p/1050061
Best Regards,
Nutan
varunbaskar
yes, that's the link I used for migrating the project to Vitis. That's when Vitis removed all the projects automatically somehow.
nutang
Hi @varunbaskar
Can you share the Vitis log, maybe there is some error?
Best Regards,
Nutan
varunbaskar
Vitis doesn't show any error logs. But I performed the steps again and this time it does show the bit stream and other system related files under the project. Is the elf generation still involved or is that too removed like the hdf?
