_quang_
XSCT -- Adding sysroot path to application
Hi, I have created a linux project and now I'm trying to figure out how to add the sysroot with XSCT. I am able to do this with the VITIS IDE but I want to know how to do it with XSCT so I can better streamline my company's workflow.
longley
@_quang_
Please check below -sysroot option in "domain create" command.
https://www.xilinx.com/html_docs/xilinx2020_2/vitis_doc/bid1585821551210.html?hl=domain
Longley
If starting with Versal take a look at our Versal Design Process Hub and our
Versal Blogs
longley
@_quang_
Longley
Versal Blogs
pvempati
Hi @_quang_ ,
Use this sample code to add the sysroot.
set sysroot /tmp/xbuilds_sysroot/cortexa9t2hf-neon-xilinx-linux-gnueabi
set appname hello
set proc_opt   ps7_cortexa9
set target  Debug
setws $work_dir
platform create -name hw_platform -hw [file normalize $xsa_file] -no-boot-bsp
domain create -name "linux_domain" -os linux -proc $proc_opt
file mkdir linux/images
domain config -image  [ file normalize ./linux ]
domain config -boot   [ file normalize ./linux/images ]
domain config -bif    [ file normalize ./linux/images/dummy.bif ]
domain config -sysroot [file normalize $sysroot]
platform generate
app create -proc $proc_opt -os linux -name $appname -template {Linux Hello World} -lang c
app config -name $appname -set build-config $target
_quang_
Great. Thank you!
