XSCT: how to set compiler settings for library project
I would like to automate project creation for Vitis 2019.2 using TCL scripting.
I need to customize few compiler options and this seems to be possible only for application projects.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug1400-vitis-embedded.pdf
https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/Chunk286545141.html#esn1543754645434
I have a library project and there is not "library config" option available. Why is it missing?
Best Regards
Hi @itmadem1,
For the moment, there is no XSCT command to configure a library project created by "library create".
We are aware of that and a new command "library config" will be added in future releases for that purpose.
For the moment and as a workaround, if you are using 2019.2, we have a patch that allows you to use "app config" with library projects.
To apply the patch, please extract the attached zip file, and set MYVIVADO environment variable to the extracted directory with name myvivado.
This patch is made on top of 2019.2 release. Changes are in sdk.tcl file.
Please note that this is a temporary fix. Without this patch "app config" won't work with library projects and it won't do that in future releases. "app config" is not intended to be used with library projects and you have to update the command in your script to "library config" as soon as you upgrade to a future release that support this new command.
Best regards,
Abdallah
I discovered the same issue and would like to know why there is a difference between Vitis IDE and XSCT. In addition, the XSCT "library create" command will always create a C project and there is no option to create a C++ library. These all seem like significant limitations.
If you want to change the library options from XSCT
To get all the params current on your lib:
  • bsp listparams -lib <your library name>
  • bsp config <param> <value>
For example, this is for a custom library I created and added:
actually I was referring to library projects created in the workspace with the "library create" xsct command (or the "New Library project" wizard in the IDE).
You are proposing to define a custom library using MLD to be included in the BSP. Yes, it can be an alternative... I will try this approach, it seems more flexible but also much more complex.
Thank you for your reply
Hi @itmadem1,
Best regards,
Abdallah
Ok, I will try the patch.
Thank you and best regards
You are welcome @itmadem1
Best regards,
Abdallah
Hi, is there also a patch available for Vitis (XSCT) 2020.1 on Windows? Thx.
