vas_peter
[XSCT setlib command] - cannot add lwip141 to bsp
I cannot add the lwip141 library to a bsp project using the setlib command.
Syntax:
setlib -bsp $name\_bsp -lib lwip141
I don't get any error messages, but the folder for this library does not show in the 'libsrc' directory. Also, the system.mss file is not updated.
I also tried specifying the -ver parameter.
I tried to add the xilffs library to test the command itself and it was successfully added. Seems like it is just the lwip141.
sadanan
Hi @vas_peter
Modifications to BSP take effect after running regenbsp -bsp <bsp_name>
sadanan
Hi @vas_peter
