02-28-2018 03:14 AM
After exporting the hardware and bit file for the SDK, I luanch the SDK.
However, when I try to create the example 'hello world' project, it fails.
The SDK log contains:
13:06:20 INFO : Registering command handlers for SDK TCF services 13:06:20 INFO : Launching XSCT server: xsct.bat -interactive C:\Users\Owner\Documents\adi\hdl\projects\ad9739a_fmc\ac701\ad9739a_fmc_ac701.sdk\temp_xsdb_launch_script.tcl 13:06:21 INFO : XSCT server has started successfully. 13:06:21 INFO : Successfully done setting XSCT server connection channel 13:06:21 INFO : Processing command line option -hwspec C:/Users/Owner/Documents/adi/hdl/projects/ad9739a_fmc/ac701/ad9739a_fmc_ac701.sdk/system_top.hdf. 13:06:21 INFO : Successfully done setting SDK workspace 13:07:00 ERROR : (XSDB Server)ERROR: [Hsi 55-1545] Problem running tcl command ::sw_intc_v3_7: 13:07:00 ERROR : (XSDB Server):generate : can't read "source_name(13)": no such element in array while executing "string compare -nocase $source_name($i) "system"" ("foreach" body line 18) invoked from within "foreach periph $periphs { #update global array of Interrupt sources for this periph intc_update_source_array $periph lappend ..." (procedure "xredefine_intc" line 21) invoked from within "xredefine_intc $drv_handle $file_handle" (procedure "xdefine_canonical_xpars" line 72) invoked from within "xdefine_canonical_xpars $drv_handle "xparameters.h" "Intc" "DEVICE_ID" "C_BASEADDR" "C_HIGHADDR" "C 13:07:00 ERROR : (XSDB Server)_KIND_OF_INTR" "C_HAS_FAST" "C_IVAR_RESET_VALUE" "C..." (procedure "::sw_intc_v3_7::generate" line 57) invoked from within "::sw_intc_v3_7::generate axi_intc" ERROR: [Hsi 55-1442] Error(s) while running TCL procedure generate()
03-01-2018 01:03 AM
03-01-2018 01:03 AM
03-04-2018 06:00 AM
These problems arose from changes I made to the block design. I removed signals that were concatanated into a wide signal of interrupts. Strangely, the whole thing validated and was made into a bitstream without warning.
04-03-2018 03:40 PM
@simchask, What was the fix? I am having the same exact problem with my design, failing also on the sw_intc_v3_7 block.
Tim
04-10-2018 06:56 AM
This is marked solved yet shows no solution. I am having the exact same problem with the interrupt controller.
Jeff
04-10-2018 07:00 AM
In my block design my concat block going into the interrupt controller had an input that was floating. I believe once I reimplemented without a floating input then things started working.
Tim
04-10-2018 10:29 AM
04-10-2018 10:31 AM
04-17-2018 12:34 AM
I had to rewrite the interface of the modules being instantiated to account for the fact that I deleted some pins.
05-14-2019 04:14 PM
Thank you !! ... you would think this could be a validation error ?!?!?!
03-09-2021 02:57 AM
I did the same thing... I have connected the input of my concat ip to the interrupt o/p of the uartlite... and there is no floating input in my concat ip.... things are still not working...
bu one floating i/p (aux_reset_in) and one floating o/p (peripheral_reset) are still there in Processor System Reset ip ... Can you please tell me whether these two floating pins are creating the problem or not ...
