simchask
(XSDB Server)ERROR: [Hsi 55-1545] Problem running tcl command
After exporting the hardware and bit file for the SDK, I luanch the SDK.
However, when I try to create the example 'hello world' project, it fails.
The SDK log contains:
13:06:20 INFO  : Registering command handlers for SDK TCF services
13:06:20 INFO  : Launching XSCT server: xsct.bat -interactive C:\Users\Owner\Documents\adi\hdl\projects\ad9739a_fmc\ac701\ad9739a_fmc_ac701.sdk\temp_xsdb_launch_script.tcl
13:06:21 INFO  : XSCT server has started successfully.
13:06:21 INFO  : Successfully done setting XSCT server connection channel
13:06:21 INFO  : Processing command line option -hwspec C:/Users/Owner/Documents/adi/hdl/projects/ad9739a_fmc/ac701/ad9739a_fmc_ac701.sdk/system_top.hdf.
13:06:21 INFO  : Successfully done setting SDK workspace
13:07:00 ERROR : (XSDB Server)ERROR: [Hsi 55-1545] Problem running tcl command ::sw_intc_v3_7:
13:07:00 ERROR : (XSDB Server):generate : can't read "source_name(13)": no such element in array
    while executing
"string compare -nocase $source_name($i) "system""
    ("foreach" body line 18)
    invoked from within
"foreach periph $periphs {
        #update global array of Interrupt sources for this periph
        intc_update_source_array $periph
        lappend ..."
    (procedure "xredefine_intc" line 21)
    invoked from within
"xredefine_intc $drv_handle $file_handle"
    (procedure "xdefine_canonical_xpars" line 72)
    invoked from within
"xdefine_canonical_xpars $drv_handle "xparameters.h" "Intc" "DEVICE_ID" "C_BASEADDR" "C_HIGHADDR" "C
13:07:00 ERROR : (XSDB Server)_KIND_OF_INTR" "C_HAS_FAST" "C_IVAR_RESET_VALUE" "C..."
    (procedure "::sw_intc_v3_7::generate" line 57)
    invoked from within
"::sw_intc_v3_7::generate axi_intc"
ERROR: [Hsi 55-1442] Error(s) while running TCL procedure generate()
ibaie
Hi @simchask,
It seems that the BSP generation had an issue when running the interrupt controller generation part.
What device are you using? and which OS BSP (standalone or FreeRTOS)?
Ibai
ibaie
Hi @simchask,
Ibai
simchask
These problems arose from changes I made to the block design. I removed signals that were concatanated into a wide signal of interrupts. Strangely, the whole thing validated and was made into a bitstream without warning.
tim_severance
@simchask, What was the fix?   I am having the same exact problem with my design, failing also on the sw_intc_v3_7 block.
Tim
jmackin
This is marked solved yet shows no solution. I am having the exact same problem with the interrupt controller.
Jeff
tim_severance
@jmackin,
   In my block design my concat block going into the interrupt controller had an input that was floating.   I believe once I reimplemented without a floating input then things started working.
Tim
jmackin
@tim_severance
That worked! Thanks!
-Jeff
tim_severance
@jmackin,
   Great news!
Tim
simchask
I had to rewrite the interface of the modules being instantiated to account for the fact that I deleted some pins.
othane
Thank you !! ... you would think this could be a validation error ?!?!?!
gitesh@xilinx
I did the same thing... I have connected the input of my concat ip to the interrupt o/p of the uartlite... and there is no floating input in my concat ip.... things are still not working...
bu one floating i/p (aux_reset_in) and one floating o/p (peripheral_reset) are still there in Processor System Reset ip ... Can you please tell me whether these two floating pins are creating the problem or not ...
