(XSDB Server)ERROR: [Hsi 55-1550] Repository Directory ".../drivers" doesn't exist in the disk
Hi folks,
I have a problem with Vivado/SDK 2018.1:
When I want to create a new Hardware Platform Specification I get the error:
(XSDB Server)ERROR: [Hsi 55-1550] Repository Directory C:/My_SoM_Project/Software/my_test/drivers doesn't exist in the disk
To me, it looks like SDK looks for the driver repository in my newly created project, instead of the SDK base directory (C:\Xilinx\SDK\2018.1\data\embeddedsw\XilinxProcessorIPLib\drivers)
Does anybody have a clue how to solve this problem?
Simon
Re: (XSDB Server)ERROR: [Hsi 55-1550] Repository Directory ".../drivers" doesn't exist in the disk
Hi @richnsim,
The error message seems to be more related to some custom IP in your Vivado design which does not have any associated driver. Do you have any custom IP in your design?
Ibai
Ibai
Hi @richnsim,
Ibai
Ibai
Hi @ibaie
You are right. The problem was, that I created a custom IP using the Vivado "Create AXI4 Peripheral" tool.
This automatically adds some software driver files to the IP repository. By default, these files are referenced in the IP's "component.xml" file.
My problem was, that when committing to our GIT repository, I didn't add these driver files, because they didn't seem to be much of use. After cloning the repository to a new working location, the error I mentioned started to occur.
Meanwhile I found out, that this can be avoided when the "Software Driver" folder is removed from the "File Groups" list during packaging the IP.
Thanks for your help,
Simon
