XSDK 2017.2 - build linux kernel with unkown error
I installed XSDK 2017.2, and downloaded the xilinx uboot, kernel,
then build the u-boot successfully, when build the linux kernel, error occurs,
The command is as follows:
fivepanda@ubuntu:~$ which xsdk
fivepanda@ubuntu:~$ source xilinx/SDK/2017.2/settings64.sh
/home/fivepanda/xilinx/SDK/2017.2/bin/xsdk
fivepanda@ubuntu:~$ cd gitadi/zynq_xcomm/
fivepanda@ubuntu:~/gitadi/zynq_xcomm$ make ARCH=arm zynq_xcomm_adv7511_defconfigMakefile:344: scripts/Kbuild.include: No such file or directory
make: *** empty variable name.  Stop.
Makefile:448: recipe for target 'scripts_basic' failed
make: *** [scripts_basic] Error 2
I tried to find the cross-compile tool:
fivepanda@ubuntu:~/gitadi/zynq_xcomm$ which arm-linux-gnueabigf-
Is there something I missed?
sorry, my mistake, the linux file is not intact.
