[XSDK 2018.2] program_flash fails to open file
I am trying to flash a custom zynqmp based HW using program_flash (XSDK 2018.2) through JTAG, which seemingly fails to open the file behind a symbolic link:
martin@dell:~/work/z7000-distro_sumo/build/tmp/deploy/images/nanomind-ultra-zu6eg-uv1$ file Image
Image: symbolic link to Image--4.14-xilinx-v2018.1+git0+15b23f7fa8-r0-nanomind-ultra-zu6eg-uv1-20180702053346.bin
martin@dell:~/work/z7000-distro_sumo/build/tmp/deploy/images/nanomind-ultra-zu6eg-uv1$ program_flash -f Image -offset 0x320000 -fsbl ~/Downloads/fsbl.elf -flash_type qspi_dual_parallel -verify -cable type xilinx_tcf url tcp:localhost:3121
****** Xilinx Program Flash
****** Program Flash v2018.2 (64-bit)
**** SW Build 2258646 on Thu Jun 14 20:02:38 MDT 2018
** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
Connected to hw_server @ tcp:localhost:3121
Available targets and devices:
Target 0 : jsn-JTAG-HS3-210299A1F210
Device 0: jsn-JTAG-HS3-210299A1F210-24739093-0
Retrieving Flash info...
Initialization done, programming the memory
ERROR: Flash Operation Failed
However flashing the file behind the symbolic link seems to work:
martin@dell:~/work/z7000-distro_sumo/build/tmp/deploy/images/nanomind-ultra-zu6eg-uv1$ program_flash -f Image--4.14-xilinx-v2018.1+git0+15b23f7fa8-r0-nanomind-ultra-zu6eg-uv1-20180702053346.bin -offset 0x320000 -fsbl ~/Downloads/fsbl.elf -flash_type qspi_dual_parallel -verify -cable type xilinx_tcf url tcp:localhost:3121
===== mrd->addr=0xFF5E0204, data=0x00000000 =====
BOOT_MODE REG = 0x0000
Downloading FSBL...
Running FSBL...
Finished running FSBL.
U-Boot 2018.01-00071-g0018654-dirty (May 01 2018 - 11:30:07 -0600)
Model: ZynqMP MINI QSPI
Board: Xilinx ZynqMP
DRAM: 256 KiB
EL Level: EL3
Using default environment
In: dcc
Out: dcc
Err: dcc
ZynqMP> sf probe 0 0 0
SF: Detected mt25ql02g with page size 512 Bytes, erase size 128 KiB, total 512 MiB
ZynqMP> Sector size = 131072.
f probe 0 0 0
Performing Erase Operation...
sf erase 320000 E00000
SF: 14680064 bytes @ 0x320000 Erased: OK
ZynqMP> Erase Operation successful.
INFO: [Xicom 50-44] Elapsed time = 1 sec.
Performing Program Operation...
0%...sf write FFFC0000 320000 20000
Host OS is Ubuntu 17.10. Other symbolic links (generated by Yocto) seems to work just fine.
Is this the right place for a bug report?
Martin
Hi @mnsgs
I just tested it from my side using a symbolik link to the boot image and it does work for me, so I think it's not an issue related to that fact. The only two reason I can figure out right now is either a corrupted symbolik link or issues with the hardware when you tried to test it.
Can you redo the testing?
Ibai
Ibai
Hi @ibaie,
Flashing files through symbolic links works in general, issue is specific for this particular link/file. As stated previously and below:
martin@dell:~/work/z7000-distro_sumo/build/tmp/deploy/images/nanomind-ultra-zu6eg-uv1$ ls -laH Image
-rw-r--r-- 2 martin martin 14608896 Jul 2 08:06 Image
the link seems to be fine. I tried multiple combinations of file/link names but encounter the same issue nevertheless.
As discussed in the other thread I can provide the artifacts for you to reproduce.
Martin
Hi @ibaie,
Any update on the topic:
1) Did you receive the provided artifacts?
2) Did you manage to reproduce the issue?
3) Can we expect it resolved in 2018.3?
Martin
