asandweech
XSDK Eclipse crashes during libmetal BSP generation
Hello, I am attempting to create a SDK project using the RFDC driver which, to my understanding, is dependent on the inclusion of the libmetal library. When I create a new BSP or modify an existing BSP to include the libmetal library any subsequent BSP source generation will lock up/freeze Eclipse. In order to prevent a full crash the rdi_xsct process has to be manually killed.
Has anyone had any similar experiences, or any tips on successfully including libmetal in a BSP? I am experiencing this with version 2018.2 on Windows 7, and I am currently working to see if the same thing happens using version 2018.3.
Apologies if this is the wrong location for this post, I wasn't sure which board is most appropriate and now I am thinking the embedded processor board might be more correct. If someone could move this post to the proper location, it would be appreciated.
stephenm
You could just create the BSP first, and enable the libmetal lib. Then when created the applciation project, you can select the pre-existing bsp instead of the default create new bsp
asandweech
That is what I have been attempting to do, as I had previously found this thread: https://forums.xilinx.com/t5/Evaluation-Boards/ZCU111-RFDC-Bare-Metal-Example/td-p/897245
Unfortunately my issues were not solved in the same way as them by creating the BSP independently. The lockup/crash occurs after exiting the new BSP wizard and again when attempting to manually trigger the BSP source generation.
asandweech
Just a follow up, updating the Vivado installation to 2018.3.1 does not seem to have made a difference; the issue still persists. I seem to be experiencing the same issue as what is described in this OpenAMP post: https://groups.google.com/forum/#!msg/open-amp/vsj4tt5ZlQQ/snfKHgpUCAAJ
The issue is not present when using 2018.3 on Linux (Ubuntu 16.04), so for now that serves as a workaround.
tmonaghan84
I am also seeing this issue using SDK 2018.2 on windows 7 (64) using the ZCU111 hdf.
The SDK will hang of the libmetal library is included in the BSP project.
Workaround (manual build using XSCL)
Open XSCL and type;
setws {<workspace path>}                          ## The curly braces are needed for windows paths only, do not include the trailing slash this will hang the command line.
getprojects ##This should list the projects to check you are in the right workspace regenbsp -bsp <bsp name>
Notes:
Paths in XSCL in windows require double slash/backslash (either can be used) e.g. "setws C:\\workspace\\project_1\\"
Windows paths require the path is wrapped in curly braces as mentioned above
The <workspace path> has to be a parent of the <project path> , otherwise the XSCL will not find the project/bsp.
The <bsp name> is normally "standalone_bsp_1"
I have attached trace Log from the SDK for the crash, line 1336 is the crash, "rdi_xsct.exe" process was then terminated
Hopefully Xilinx can identify this issue and document the work around.
stephenm
I have tested this on my end:
  set fsbl_design [hsi::create_sw_design fsbl_1 -proc psu_cortexa53_0 -app zynqmp_fsbl]
  common::set_property APP_COMPILER "aarch64-none-elf-gcc" $fsbl_design
  common::set_property -name APP_COMPILER_FLAGS -value "-DRSA_SUPPORT -DFSBL_DEBUG_INFO -DXPS_BOARD_ZCU111" -objects $fsbl_design
  hsi::add_library libmetal
  hsi::generate_app -dir zynqmp_fsbl -compile
This uses the HSI (meaning non eclipse based).
tmonaghan84
@stephenm I assume you can recreate the hang/crash regenerating the libmetal library?
Does the HSI mean its a Xilinx problem then?
stephenm
There is a known issue in the SDK for HDF with the RFDC IP when building the BSP. The libmetal library isnt added, therefor the comilation of the rfdc drvier will fail.
The issue isnt in the HSI. The commands I sent in the previous post is how you can create a BSP in HSI that will enable the libmetal before the bsp is compiled
tmonaghan84
Ah appologies, my misunderstanding.
As this has been acknowledged can you clarify which version(s) of the SDK this effects?
tmonaghan84
Using Xilinx SDK 2019.1 and creating a BSP for the ZCU104 (MPSoC which does not contain an RFDC) also fails regenerating the libraries when libmetal is included, this suceeds when libmetal is excluded.
Line that hangs in the SDK.
DEBUG : XSCT command with result: [::hsi::utils::generate_bsp_sources C:/Users/username/workspace/regen3/zcu104_design_wrapper_hw_platform_0/system.hdf C:/Users/username/workspace/regen3/standalone_bsp_0/system.mss C:/Users/username/workspace/regen3/standalone_bsp_0], Result: null. Thread: ModalContext
nueskr1
I am also encountering this behavior.  Is there any workaround?  I've reinstalled the XSDK, but it still hangs.
tmonaghan84
This is a known issues that libmetal does not generate with eclipse upto and including 2019.1.
You need to;
  1. Create the BSP with Xilinx SDK
  2. Open BSP settings , and add libmetal, and any other libraries you need.
  3. open windows task manager and termate "rdi_xsct.exe"
  4. Open XSCT;
  5. setws {<workspace_path}
  6. getprojects          (This should list all SDK projects)
  7. regenbsp -bsp <bsp_name>
  8. close XCST
  9. reopen project with Xilinx SDK.
If you need to add/remove bsp libraries you will need to go through these steps again.
