hbaumann
XSDK/XSCT: WARNING: [Hsi 61-9] Current Software design may not be compatible with "zynq_fsbl" app. Tool is ignoring the MSS file specified in the app directory
I try to generate an FSBL with the help of XSCT. Therefor I have written this small tcl-script:
puts "starting tcl-script"
#setting workspace
setws /tmp_fsbl
#get all projects in the workspace and assign the list to the "myprojects"-variable
set myprojects [getprojects -type all]
#step through the list of projects and delete them
foreach element $myprojects {
puts "deleting $element"
deleteproject -name $element
puts "creating hardware specification"
createhw -name hw_test_master -hwspec /tmp_fsbl/top_wrapper_masterBranch.hdf
puts "create FSBL"
createapp -name fsbl_test_master -app {Zynq FSBL} -proc ps7_cortexa9_0 -hwproject hw_test_master -os standalone
puts "add compiler-symbol FSBL_DEGUB_INFO + FSBL_DEBUG"
configapp -app fsbl_test_master define-compiler-symbols FSBL_DEBUG_INFO
puts "configure bsp and update system.mss"
configbsp -bsp fsbl_test_master_bsp stdin ps7_uart_1
configbsp -bsp fsbl_test_master_bsp stdout ps7_uart_1
updatemss -mss /tmp_fsbl/fsbl_test_master_bsp/system.mss
regenbsp -bsp fsbl_test_master_bsp
puts "build projects"
projects -build
puts "script finished ........."
This seems to work kinda fine and finishes successfull (fsbl was generated).
My problem is that I get this warning:
when executing this line:
Like I said, the script produces a fsbl which seems to work. Only problem I encounter is that I dont see any debug messages of the fsbl. Im kinda certain that is related to the warning above. I think my changes to the stdin/stdout are ignored.
I dont know why my design shouldnt be compatible "zynq_fsbl". Im working with an "XA7Z010" and defined this in the Vivado project.
Can someone give me an hint why this warning appears and the system.mss file is ignored.
Heiko
ibaie
Hi @hbaumann
I'm guessing that the warning might be related to the fact of being XA (automotive) device, so the tool get confused and issues the warning. Anyway could you let me know which release of the tool are you using?
Ibai
hbaumann
Hi @ibaie ,
I'm using the 2018.02 Version of Vivado and XSDK/XSCT. I also tried it with earlier versions like 2017.02 with the same result.
Heiko
ibaie
Hi @hbaumann
The warning message regarding the platform seems to be just an issue related to XA device not being properly identified by the scripts. Anyway the FSBL application is properly created so the warning message could be ignored safely. Testing on newer releases of the tools the issue has been already fixed.
The fact that is not priting the anything in the serial port seems to be strange. I would suggest to open the workspace with SDK and check the following points:
  1. The serial port has been updated in the BSP configuration
  2. Application project has FSBL_DEBUG and FSBL_DEBUG_INFO symbols defined
  3. Debug the FSBL application in the target and ensure it is properly executing
Ibai
