XSDK can't find download.bit
I'm having a strange problem where I try to program my MicroBlaze design onto my board. I program in the usual way, specify bitstream, and .mmi file and .elf, but when it goes through the programming process, it fails when it can't find <filepath>/download.bit.
This is unsurprising, because the bitstream generated by my project is called design_1_wrapper.bit. (and when I specify the bitstream in the 'program FPGA' dialogue box, I specify design_1_wrapper.bit.
So why is XSDK trying to source a bitstream called download.bit? It says it is missing from my hardware platform folder, which is exactly where my design_1_wrapper.bit is. I tried to work around this by renaming the bitstream file to download.bit but this causes BRAM init to fail. How can I fix this? Can I specify in the elf or something which bitstream to use?
Thanks for your time
--- Estimated Development time: 2*Pi*(planned completion date) ---
Re: XSDK can't find download.bit
The boot loader will run in bram. It will take image from flash and put it in ddr, then handover to ddr app.
Your is as you described was that you had sections of linker in DDR. The updatemem can't map to ddr. So it failed.
So, either place all sections in bram, or use the SDK to download, or use a srec boot loader.
Hi @aaron_holliday
SDK tries to create download.bit from <user>.bit and elf. It looks like this is failing, but SDK is ignoring the error and trying to program download.bit. Can you please post the log from updatemem and program FPGA consoles
Hi @sadanan
Sorry for the wait, I have got the program FPGA log here:
cmd /C updatemem -force -meminfo \
C:/Users/<FILEPATH>/project1.sdk/design_wrapper_5/design_1_wrapper.mmi \
-bit \
C:/Users/<FILEPATH>/project1.sdk/design_wrapper_5/design_1_wrapper.bit \
-data \
C:\Users\<FILEPATH>\deip_cpu\project1.sdk\tcp_server_7\Debug\tcp_server_7.elf \
-proc design_1_i/microblaze_0 -out \
C:/Users/<FILEPATH>/project1.sdk/design_wrapper_5/download.bit
****** updatemem v2018.1 (64-bit)
**** SW Build 2188600 on Wed Apr 4 18:40:38 MDT 2018
** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
source C:/Xilinx3/SDK/2018.1/scripts/updatemem/main.tcl -notrace
CRITICAL WARNING: [memdata-28-246]
ERROR: [Updatemem 57-153] Failed to update the BRAM INIT strings for C:\Users\<FILEPATH>\project1.sdk\tcp_server_7\Debug\tcp_server_7.elf and C:/Users/<FILEPATH>/project1.sdk/design_wrapper_5/design_1_wrapper.mmi.
update_mem: Time (s): cpu = 00:00:08 ; elapsed = 00:00:10 . Memory (MB): peak = 136.016 ; gain = 75.805
ERROR: [Common 17-39] 'update_mem' failed due to earlier errors.
INFO: [Common 17-206] Exiting updatemem at Tue Sep 18 16:15:06 2018...
I noticed that in some of the paths, the slashes are sometimes forwards and sometimes backwards. Let me know if you need other logs etc. Thanks for your time
Hi @aaron_holliday,
Can you please check if the elf is built to run from BRAM (assign the program sections to BRAM in linker script)?
Hi @sadanan
I had to program the .text and .bss to ddr4 due to their size. They exceeded my ilmb and dlmb max size. Everything else is in bram. I will double check my linkedr script when I can but I think the program sections were all bram
This is the issue, you have some sections in the.
You will need to remove these sections from the elf, or place all sections in bram
You can use objcopy to remove the section from the elf
@stephenm so I need to shrink the elf by reducing the source code size? Currently I am using a lwIP example TCP server. Is this usually too big to fit on a board? Or should I just increase my ilmb and dlmb cache sizes? Also I think your message got got cut off in your comment. Thanks for your help
The updatemem tool is used for populating bram, not ddr. This is why this is failing.
Yuou will also unlikely fit an lwip design into bram. So you will need to use the ddr.
For debugging you can use the SDK to download the elf. Going forward, you could use a boot loader to load the elf into try from a flash memory
@stephenm thanks. Is there a xilinx document for using boot loaders from flash?
There is an are boot loader template in SDK. You can use that. Yhou just need to configure it to point to your flash address
If you Google srec bootloader xilinx. There is a great off by Avnet that you can use
@stephenm great thanks for that. Two last questions, will I get issues with DDR if my design uses a MIG and it is also being used to store the bootloader? Also, will I have any issues with mmi not matching elf and design_1.bit being used instead of download.bit? Or is this solely a updatemem issue? Thanks
