Observer wpmoorenasa
XSDK deletes linker flags when opening from command line vs. Opening from Vivado.
??Why?? are my linker flags getting lost when I open XSDK from the command line:
    $ xsdk -workspace myproject.sdk &
    arm-none-eabi-g++  is  missing: ... -Wl,--start-group,-lxil,-llwip4,-lgcc,-lc,--end-group
Verses open xsdk from vivado:
   $ vivado  & #. then click around in menu: File->open sdk... or some such #$@#...
   arm-none-eabi-g++  NOT missing: ... -Wl,--start-group,-lxil,-llwip4,-lgcc,-lc,--end-group
Xilinx Tool version: 2017.3
Re: XSDK deletes linker flags when opening from command line vs. Opening from Vivado.
Hi @wpmoorenasa
Could you provide more details on how to reproduce this issue? I mean, it seems you have an application project and the BSP with LWIP libary enabled, and the linker flags missing in your Makefile only applies to the application, am I right? Again bit more details might help to understand better the issue and figure out what's going on.
Ibai
