gicgatv
XSDK linker error while trying to create Release
Good Afternoon,
I have a project in XDSK that is compiling  when I set Active the Debug configuration. When I Change to Release is not possible to compile, I have the following linker error:
18:36:17 **** Auto Build of configuration Release for project tracking ****
make all
Building target: tracking.elf
Invoking: ARM v7 Linux g++ linker
arm-linux-gnueabihf-g++ -L"/media/Fast/zedboard_root_fs/usr/lib" -L"/media/Fast/zedboard_root_fs/lib" --sysroot=/media/Fast/zedboard_root_fs/ -o "tracking.elf"  ./src/contour_finder.o ./src/disjoint_set.o ./src/hungarian.o ./src/kalman_tracker.o ./src/main.o ./src/multi_object_tracker.o ./src/tracker_log.o   -lm -lswresample -lz -lavformat -lopencv_calib3d -lopencv_core -lopencv_imgcodecs -lopencv_imgproc -lopencv_highgui -lopencv_features2d -lopencv_flann -lopencv_video -lopencv_videoio
./src/tracker_log.o: In function `nlohmann::basic_json<std::map, std::vector, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, bool, long long, unsigned long long, double, std::allocator>::dump(std::ostream&, bool, unsigned int, unsigned int) const':
tracker_log.cpp:(.text._ZNK8nlohmann10basic_jsonISt3mapSt6vectorNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEbxydSaE4dumpERSobjj[_ZNK8nlohmann10basic_jsonISt3mapSt6vectorNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEbxydSaE4dumpERSobjj]+0x204): undefined reference to `std::__cxx11::numpunct<char>::_M_initialize_numpunct(int*)'
tracker_log.cpp:(.text._ZNK8nlohmann10basic_jsonISt3mapSt6vectorNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEbxydSaE4dumpERSobjj[_ZNK8nlohmann10basic_jsonISt3mapSt6vectorNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEbxydSaE4dumpERSobjj]+0xf54): undefined reference to `std::__cxx11::numpunct<char>::_M_initialize_numpunct(int*)'
makefile:48: recipe for target 'tracking.elf' failed
collect2: error: ld returned 1 exit status
make: *** [tracking.elf] Error 1
18:36:18 Build Finished (took 465ms)
I'm using the 2017.4 XSDK. I'm compiling the app for Petalinux 2017.4, I have a folder with petalinux In path with XSDK. I'm using OpenCV 3.1 Libraries... Everything works fine in debug mode, the elf is working on my Zed Board, but in Release mode I'm not able to compile.
Any help will be really appreciated!
gicgatv
At the end I've found a possible workaround.
It depends on the optimization level. In Debug The XSDK optimization level is -O0 while in Release is -O2.
Is possible to change the optimization going in project Properties->Settings->ARM v7 Linux g++ compiler->Optimization (like shown in the following picture).
I had a Doubt: Which optimization is recommended and supported by ARM? I have surfed over Internet and various sites recommend:
  • Compile with compiler options for smallest code size (-Os) in release mode
  • Compile with compiler options for optimized debugging (-Og) in debug mode
as you can read in the following reference
http://blog.atollic.com/optimizing-code-size-with-the-gnu-gcc-compiler-for-stm32-and-other-arm-cortex-m-targets
Looking to the XSDK optimization options I decide to use -O0 for Debug and -Os for Release, because the others choices (-O1 -O2 -O3) seems not be supported by ARM.
sadanan
Can you please post a testcase so that we can look into this?
gicgatv
What do you mean with test case? Do you want I post the code?
gicgatv
