pedro_uno
Advisor
Advisor
XSDK workspace setup using XSCT TCL script?
Hello Guys,
I'm doing a bare metal project in XSDK. I don't like memorizing Eclipse gui procedures so I wrote a little tcl script that runs in the Xilinx Software Command Line Tool (XSCT) shell. I just checkout my files from the subversion repository and run the tcl script. It pulls in the .hdf file, creates a bsp and creates an application containing my code.
Unfortunately, there are a couple of steps that I still do manually in the gui. I have to add libm to the C Libraries settings because I use sin() and cos(). After that, I have to create a Run Configuration.
I looked at UG1138 and UG1208 but saw nothing on this.  Maybe this is more of an Eclipse issue than XSDK.
Are there XSCT tcl commands to add libm and create run configurations?
DSP in hardware and software
sadanan
To add libm to the app, you can run "configapp -name <app-name> libraries m" ;# replace m with any other library you want to use (do not include -l or -lib while adding libraries like this)
There is no option to create a run configuration from XSCT. However, you can use debug commands to run your application. When you run/debug an app from GUI, you'll see a dump of debug commands in the LOG view. You can copy those commands to your XSCT script, or write the commands manually. Please refer to
https://www.xilinx.com/html_docs/xilinx2017_4/SDK_Doc/xsct/use_cases/xsdb_standalone_app_debug.html for an example
sadanan
pedro_uno
Advisor
Advisor
This seems to work except that in XSDK 2017.4 I had to use -app option, not -name.
    "configapp -app <app-name> libraries m"
