XUPV5 LX 110t is not listed in XPS
Hello..
There is no XUPV5 LX110T in XPS board list.  So which 1 i should choose??
Virtex 5 ML505 evaluation platform ?? Or Should i go for coustom board??
Or is there any way i can add XUPV5 LX110T board to that list??
Community Manager
Community Manager
Re: XUPV5 LX 110t is not listed in XPS
Hi Harsha,
ML505 has XC5VLX50T device. So, you can't choose it for your board.
You need to set the device part manually instead of choosing a eval. board.
Krishna
Hi Harsha,
You can try including the xbd file available at http://www.xilinx.com/univ/xupv5-lx110t-bsb.htm to see the XUPV5 board in list.
The xbd file is available at EDK-XUPV5-LX110T-Pack in the above location.
Follow the procedure mentioned in this pdf http://www.xilinx.com/univ/xupv5-lx110t/design_files/BSB_CREATE/xupv5-lx110t_bsb_design_creation.pdf
Thnx
Hello,  I followed the above PDF document.  But m getting lots of errors.. . Can you tell me what it is?
"ERROR:Map:11 - FDRSE symbol
"DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/g en_dq[4].u_iob_dq/gen_stg2_sg1.u_ff_stg2a_rise" (output
signal=DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_
io_0/gen_dq[4].u_iob_dq/stg2a_out_rise) - more than one RLOC_ORIGIN attribute
found within the RPM set "DDR2_SDRAM/hset".  "
Hi Harsha
I am not sure which version of XPS you are using. Please use the recommended version mentioned in the PDF.
--Hem
