Xil_AssertNonvoid macro ?
I am trying to solve an issue.
I think I have to understand this function at first:
u32 XIOModule_DiscreteRead(XIOModule * InstancePtr, unsigned Channel)
	Xil_AssertNonvoid(InstancePtr != NULL);
	Xil_AssertNonvoid(InstancePtr->IsReady == XIL_COMPONENT_IS_READY);
	Xil_AssertNonvoid((Channel >= 1) && (Channel <= XGPI_DEVICE_COUNT));
	return XIOModule_ReadReg(InstancePtr->BaseAddress,
			((Channel - 1) * XGPI_CHAN_OFFSET) + XGPI_DATA_OFFSET);
What is purpose of this macro Xil_AssertNonvoid ?
Kindly, I attached my SDK files.
This macro is used to ensure that the condition/expression specified as an argument is true. For example, the first instance makes sure that InstancePtr is not NULL, otherwise it raises a failure
